Question about Maytag Neptune MAH5500B Front Load Washer
Maytag coin operated extra large commercial washing machine
We have a maytag coin operated extra large commercial washing machine the coin display says colors 0 minutes which looks like its stuck on the end of a cycle but the door isnt locked is there some way we can reset it ?
  • Anonymous Mar 08, 2009
    HOW TO CHANGE PRICE AMOUNT
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
Washer_tech
  • 164 Answers
SOURCE: repair the maytag commercial washer with out coins selector
your bearings are going bad. you need to replace the bearing on the top of the brake packag and might have to replace the tub bearing also
Posted on Dec 18, 2007
AlmostBob
  • 550 Answers
SOURCE: maytag commercial washing machines/dryers that
push in slide coin acceptor,b48b65c.jpg requires different slide
multi coin single slot acceptor, ee120a2.jpgneeds new program
Posted on Oct 28, 2008
landsend
  • 1066 Answers
SOURCE: maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Posted on Mar 11, 2009
Maytag Coin Washer can't select Cycle after putting in coins
check the coin mech
If it is turning on properly
check the selector itself.possibly the switch
Mar 18, 2015 | Maytag MAH21PDD Commercial Front-Load...
Can i bypass the coin operation on my washer and dyer that i bought at a auction it came with no key
There's a reset button next to the coin box can adjust the $ to 0. Like resetting a clock
Oct 11, 2010 | Maytag MAT12CSD Top-Load Coin Operated...
What is the difference between the VX2652H and the VX2652B?
The Sharp VX-2652H is a commercial calculator that prints in 2 colors, extra large display,Special features include 3-level (sub/total/grand) totaling, markup keys, tax keys, a 4-key memory and item count. AC operation. 2.75"H x 9.83"W x 12.5"D.
The Sharp VX-2652B is a scientific calculator,
Quick and quiet 12 digit print/display calculator with stored memory tax rate key and 4 key memory. Large, easy-to-read 12 mm display.Features .Comfortable Cylindrical Step-sculptured Keys . designed for fast and comfortable operation. Extra ease is provided by contoured Plus/Equal and Minus/Equal keys.
So the difference is 1 is a commercial calculator and the other is a scientific calculator.
Sep 07, 2010 | Sharp VX-2652B Calculator
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Can't interrupt the washing cycle on coin operated Mah21pddww
Unplug the washer, wait three minutes for the door to unlock then do what you need and plug it back in. Should still have the time left on it that was there when you unplugged it.
Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need to reset price for washer and dryer
if its not working board might be bad
May 18, 2009 | Maytag Washing Machines
Maytag commercial washing machines/dryers that use tokens. is it easy to convert these to accepting coins instead? how is this done?
Oct 28, 2008 | Maytag Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
1,048 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
