Question about Novelty Scooby-Doo Corded Phone
Scooby doo novelty animated phone doesent work
When you turn on the switch for the animation all you hear is a whiring like the motor is running and you get no effects when you press the demo button or when the phone rings. there are no voives no movement, you should not hear the motor until the phone is activated.
The Dyson Vacuum Animal DC25 stopped running and will not turn on. Are there fuses some place that can be replaced or other ideas?
First check the cord for proper voltage, if that's good check the switch. If still good, cjpheck cord from switch to motor, if all is good check the motor.
Jan 12, 2017 | Dyson DC25 Animal Bagless Upright Vacuum
Please wait keeps flashing on the screen and the clock loses time
OEM radio issues. Flashing Time. Radio Not Working... - Drive ...
www.driveaccord.net/.../51717-oem-radio-issues-flashing-time-radio-not...
Sep 20, 2010 - When I reconnected the battery, the radio does not work anymore. ... I reconnected it, turned the key and the clock is still flashing. ... Wait about three minutes or so, and reinstall the fuse. .... Please let us know what it was. .... Naviscreen comes up but I can't do anything with it because the buttons are dead.
Novelty Simpson Jukebox Alarm Clock Radio Homer ... - Fixya
www.fixya.com/search/p94498-novelty...clock/welcome_please_wait
Novelty Simpson Jukebox Alarm Clock Radio Homer Simpson Animated Jukebox Alarm ... ...welcome Please Wait" Every time I try to use any handset the screendisplays ... This keeps flashing for several minutes, and never seems to resolve.
Troubleshooting - Shop - SiriusXM Radio
Jan 16, 2016 | Audio Players & Recorders
Why want the beater bar turn?
There are a few things it could be. Pull the handle back into the vacuuming position and turn the brush bar switch on and off while listening to see if you can hear the brush bar motor turn off and on. If you can hear the brush bar motor running it may need a new belt and/or the brush bar may be seized up.
There is a switch by the main power switch that provides power to run the brush bar motor. There is a micro switch down in the motor area that closes the circuit to the brush bar motor when you pull the handle back. Check electrical connections and all of the above parts to determine which one or one's may be defective.
Jul 09, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
What are novelty candles?
Novelty candles are candles that are fun. They use colors, themes and patterns to turn the regular candle into something a bit different.
Feb 07, 2013 | Crafts & Hobbies
Why is my stretch scooby hard?
Just emerge him in hot water for about 10 minutes.
Jan 05, 2012 | Scooby-doo Stretch Scooby-doo Glow In The...
DC31 Animal works but no constant power almost like you're switching it on and off constantly and because its intermittent theres not enough constant power to pick up
I'm sorry to hear you're having difficulties with your DC31 Animal. If you're experiencing an issue with intermittent power, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to establish the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 20, 2011 | Dyson DC31 Animal Bagless Handheld...
The wheels have stopped spinning on the remote contol mystery machine. How do I repair this?
If you've been running it on carpet then you have fibres wrapped around the axle. cut them off with an x-acto blade and you'll be good. If that's not the problem you may have stripped a plastic gear the motor goes on. If you have other dead r/c cars around you might be able to use a gear from one of them to fix it. Otherwise contact the manufacturer for a replacement gear.
Hope this helps!!
Nov 29, 2010 | Scooby-doo Scooby Doo Remote Control...
No demo or no animation
makes a werid noise whe i turn it on no sound or movement i have no manual for this phone how i can get this fixed
Jan 31, 2010 | Novelty Scooby-Doo Corded Phone
Dvd player won't play on the television
have you switched the tv to the av channel because a scart lead goes to the av channel shown on a remote as a box with an arrow pointing out or a av button hope this helps.
Jun 03, 2009 | Novelty Telemania 026148 Brand Disney...
Novelty Scooby-Doo Corded Phone Logo
77 people viewed this question
Top Novelty Lands Phones Experts
Are you a Novelty Lands Phone Expert? Answer questions, earn points and help others
