Question about Beverage-Air Beverage Air 2- Tap Unit Model DD78 - Stainless Steel
Beverage air dd78e not cooling
I have and older model it uses r12 and it only cools to between 50 and 60 degrees . not sure if its a thermostat problem or low freon charge.I can recharge the unit but dont know ho much it takes since the tag with that information is unreadable
  • Beverage-Air Master
  • 1,218 Answers
Change setting on thermostat and see if anything changes. If yes, that's the prob if no, freon level. start there.
Posted on Jul 11, 2010
I have a Beverage Air model MT 27. Coils have been cleaned and recharged with freon. Cooler will not cool below 50 degrees?
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Jan 28, 2011 | Beverage-Air MT27 Beverage Cooler...
Model nodd78e iceing coils or not cooling when at lower t stat setting was r12 changed to hot shot
icing coil could be improper freon level, poor air flow. If it was changed to hot shot due to a low freon level, was the leak in the system located and repair? If so, then check out the above mentioned items. If not, freon level is low due to an unresolved leak.
May 17, 2010 | Beverage-Air Beverage Air 2- Tap Unit...
Beverage Air refrigerator not cooling well
Just a warning about r12 systems. There is no more r12 unless you have a recycled. If the shop has r12 or they might be able to use something else on it. But it does sound like a leak in the system.
Might not be worth a sealed system repair.
Jul 29, 2009 | Refrigerators
I have an older beer cooler. the fan costantly runs but the refrigeration part of the beer cooler doesn't keep the keg cold? ? ? It's refrigerate is r12 cooled. Do you think I could just re charge the...
You would need to be a certified refrigeration technician to even buy R-12, since it is a CRC refrigerant. The kegerator probably doesn't have service ports so you would either have to braze a low-side port in or use a piercing valve, and fix wherever the refrigerant leaked out from. Basically, by the time you pay a refrigeration tech to do all this, it isn't worth it and you would be better off buying a new one
Jun 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
Wont cool below 50 degrees
Seems like the T-stat may have a dead spot on it since it started when you changed the settings. It is possible to trick (short) the t-stat to cause it to cool FOREVER, that would check your refrigerant charge is good. Would lean more toward t-stat problem first.
Oct 20, 2006 | Beverage-Air BM23
Beverage-Air Beverage Air 2- Tap Unit Model DD78 - Stainless Steel Logo
332 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
