Question about Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 fax machine
When we send a fax we can not hear the fax machine dial the number. We hear the beep for the buttons pushed but do not hear it dial.
  • Anonymous Mar 29, 2014
    I am trying to send a fax but I am not hearing a dial tone when I send the fax outgoing.
Same thing happened to ours here at work except it was the #3 that got stuck. It was idle for 3 weeks because no one took the time to see what was going on. Five seconds on Google and 20 seconds on fixya.com and we have a working fax machine again.
Posted on Apr 14, 2007
SOURCE:
Fax machine 2820 not working at all - just beeps no matter what button is pushed
check paper ....!! or ribbon toner is it inserted properly
hope if it helps
Apr 04, 2011 | Brother IntelliFax-2820 Laser Fax
Fax machine will not send. Dial # Push Send and
If the fax is not set for tone dailing and it is set for pulse dialing the fax will not register the # button.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
When we attempt to dial to send a fax, all we get is beeping
Check your phone line with a regular phone. Your fax machine is not finding a dial tone.
Plug the phone line into the LINE port of your fax machine.
Aug 05, 2009 | Brother IntelliFax-2820 Laser Fax
I have a Brother 2820 fax machine and it beeps when I press a button. It still receives faxes but that is it.
When it just beeps on keypress, but other functions not requiring your input (like receiving faxes), the problem most likely is a stuck button. Try pushing each button and wiggle it a little to have it "released". It may not even look pressed down, but one of them most likely is.
Jun 03, 2009 | Brother IntelliFax-2820 Laser Fax
Can not send out faxes
You have to get your phone line checked out .
Apr 28, 2009 | Brother IntelliFax-2820 Laser Fax
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Programming Auto Dial Numbers
for what model is this? are you pertaining to numbers that you call or sending faxes? you can enter the numbers as a speed dial or 1-touch key on your brother machine.
Nov 17, 2008 | Brother IntelliFax-2820 Laser Fax
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Can't receive fax
Pick up the receiver and see if you hear a fax tone noise. If so then push the start button and hang up. Is this machine on a dedicated line or shared with the main phone number? Sometimes some people will pick up the receiver on their fax machine dial the fax number and wait for a tone before sending. If this is the case the machine can not recognize that is a ax. Make sure your machine is set for auto receive if it is on a dedicated line.
Apr 06, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
223 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
