Question about EliteGroup P4M800-M7 Motherboard
Cannot boot windows xp
I have a brand new foxconn xe 925 motherboard and the problem is that i cannot boot my win xp from the cd-rom drive.i tried to set first boot device to cd-rom but it was useless. i allso tried to disable all the boot devices and i let the first boot device to cd-rom and after that i had an error that sounded like disk faileure. i have 2 hdd on ata 1 master 2 slave and 1 dvd-writer.i tried allso to boot from ms-dos but the cd-rom was not found.the freaky thing is that when i enter the windows the cd-rom is found.
PS i tried all bios configuration that normaly would woek but in my case was useless.
pls give me the exact bios configuration for boot
i tried to reebot the bios allso
thx
    Genius:
  • 1,061 Answers
Test the CMOS BATTERY..TO MAKE SURE ITS GOOD IF NOT REPLACE.If it test good leave out for 5-10 minutes replace.motherboard bios should now beat default settings.reenter the bios.move cd to first boot.save changes.if you do not save changes it will not work.place.computer should now boot from disk.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Posted on Dec 14, 2008
When the computer say press any key to contiue when i press any key they did not go
Posted on Jan 28, 2009
    Problem Solver:
  • 10 Answers
First of all on your computers motherboard,you have two connectors, one is called "IDE1 and IDE2",your hard drive plugs into IDE1,and your CD-Rom plugs into IDE2, on some older motherboards your hard drive will plug into the older models, IDE0, and your CD-Rom will plug into IDE1, the lowest IDE# is the primary boot up connector,Remember that!,now once you do that,have a look at the back of you CD-Rom and Hard Drive,you will see tiny symbols on them,one will say "primary" or PY,anther will say "cabel select" or CS,and the last will say "slave" or SE, or SL,which ever,some harddrives have a little drawing on them that will show you how to set them to primary or slave,set both of them to Primary,OK!,connect your IDE1 to you hardrive,and connect your IDE2 to your CD-rom or dvd drive,if you have two drives using one cable,one has to be set to primary,while the other is set to slave,or your computer wont boot,that is important!!Put your Window's CD into CD-Rom drive on IDE2 ,in your BIOS,deactivate your hardrive on IDE1,it will tell you the model name of your hard drive,deactivate it so it wont boot from that drive(since it does not have an operating system on it yet!,its not going to boot),now save and exit,and it will reboot,now when the computer starts it will say some thing like"cant find drive to boot from,boot from cd-rom?" press y to say "yes",or n to say "no",on some systems it will say "cant find drive,press any key to booy from CD-Rom" in which case you just push any button,and your computer will begin booting from the Cd-Rom,since you deactivated your Hardrive,the widows installation program will find it,and ask you to install the operating system on it,it will ask you to partition the drive using fat32,or NTFS, use NTFS,its better!!,and then it will begin installing after windows after that.its that easy.then update your system,on windows update.
  • Anthony Bissett
    Anthony Bissett Dec 14, 2008
    i have 2 hdd on ata 1 master 2 slave and 1 dvd-writer...
    In your case go into your BIOS and deactivate the two Hard drive's and "save and exit",make sure your Dvd is set to Master on the back of the DRIVE,Reboot,and put your windows CD into your DVD writer,and that that should be that.it will ask you to boot from that drive,and just press any key and follow the steps.
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
First bootable device
ok first u have press the delete or F2 and go to the BIOS setting and sellect the first bootable device CD rom after save and exit.. after that u insert the cd of win xp. and install the win xp... if any problem cont me...
Apr 07, 2009 | Intel D945GCL Motherboard
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Repeated boot
I supposed you are using windows xp, put the Win XP cd in your cd drive and start your computer
boot on the cd drive, wait until the winxp finishes its copying
When asked if your want to install winxp or repair [R] choose repair by pressing R
wait till the command line and type: chkdsk /r
wiat until it finishes, it may take about 20 to 30 minutes..
reboot your pc
Oct 25, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Install motherboard drivers for the first time
If you have a genuine copy of XP then it should boot from that and install it. If it's not booting from that you may have to change the boot priority in the bios, the motherboard manual will tell you how to enter the bios and make and save changes.
Are you sure it's not trying to boot from the hard drive.
As for the motherboard drivers they are installed after you put XP on.
If it's not reading the XP CD properly you may have a bad CD or CD Rom.
Mar 13, 2008 | Televison & Video
Problem with replacing the motherboard and keeping my old hard drive
Windows XP questions and answers CH000635, How to get into Windows XP recovery console without a Windows XP CD. CH000646, NTOSKRNL.EXE is missing or corrupt.
How to create a boot disk. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
How to erase my hard disk drive and start over. If you are running or plan on installing Microsoft Windows XP please see ... First, we recommend that all users wanting to simply install Windows NT use the .
How to use the Windows recovery console. Place the Windows CD in your computer and boot from the CD. ... To repair a Windows XP installation using recovery console, press R.
Good Luck, Please dont for get to Vote/Thank You.
Dec 21, 2007 | ASUS P5RD1-VM Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
365 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
