Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Ice maker removal
We need to remove the ice maker in a Maytag MFI2568aes refridgerator. Something is stuck or in a bind and we can not see or reach into it while installed.
  • vikecowboy Jan 27, 2009
    I have the same issue but I know I have ice that is jamming the ejectors. I cannot figure out how to remove the ice maker for it does not just pull out. Is there a hidden screw to undo??
    I have read to just use a plastic utensil to remove - yeah right! The utensil will break before the ice will. I need to remove the whole maker and then remove the jam.
    Thanks for anyone that can answer this question!
  • 410 Answers
First of all remove the ice bucket. then you will see a wiring cover on teh left hand wall just below teh icemaket. there is a rectangular hole in this cover. using a small precision scredriver carefullly insert into this hole and push up or and down to release a hidden clip. the trick is to pull on the wiring cover while you try to maneuver the clip. first time you do it it can be very frustrating but keep working at it and you will get it.
alternately you could just leave the Icemaker in place and use a hairdryer to melt the jammed ie out of the way. good luck peyton
Posted on Jan 28, 2009
  • 3 Answers
You need to remove this wire cover, then, on the left right below the unti there is a plastic clip you hold to the right slowly pull wntire unit out. Keep in mind, it will get hel up because of the hose coming down intoth unit, so just pull gently 3/4 of the way out. Then, disconnect the wiring and wallah, it's out.
Posted on Apr 29, 2009
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker not working
it might be out of ice, jammed, or is stuck by something...
Jun 09, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
My ice maker on Maytag MF12468AE stopped making ice. When I add water to the tray, the cubes form but are not ejected. Is the the water valve bad or is the entire ice maker itself bad?
The ice maker is bad and they have been discontinued by the manufacturer. Luckily, there is a replacement part that works in your machine, part number W10477228. The reason I say its bad is because it should have atleast ejected the ice that was made when you poured water in it if it were working properly. The only other thing it could be is that the temperature is not cold enough in the ice maker area, which is 10 degrees F or colder. If the temperature isn't at least that then the ice maker won't cycle at all.
Jun 05, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker is not working on Mod. MFI2568AES
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker not making ice..
heatman101
Oct 16, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Apr 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Ice Maker Problem Question
take the ice bin out look in the hole at the ice maker you may have a ice cube stuck between the tines of the ice maker if not look at tines somtimes they get crossed up if not that feel in the ice maker does it have water or ice in the maker? also there is a on off switch on the side of the ice maker make sure it is on, you will also see the white ice level arm you can move it up and down it is about 8 in long make sure it is free to move
May 22, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker isn't making ice...
check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
Mar 05, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
1,467 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
