Question about Indesit WA 115 Front Load Washer
No heat on Indesit IS60V tumble dryer
The timer and tumble action all works ok but the dryer has suddenly stopped producing any heat. How can I repair this? I'm guessing its the element or thermostat but have no idea how to fix. Any help appreciated!
  • indianna jon Jan 22, 2009
    Has anyone got a photo of how the electrics should be plugged in please?
    No heat.Drums turns constantly even with door open.
    Jon
  • Indesit Master
  • 3,463 Answers
The heater and stats are located at the rear of the m/c behind a removable panel.
you need a meter to test them, more likely to be a stat problem, but again you must test them for continuity.
Plz leave feed back for my solution.
Thanks.
Posted on Dec 14, 2008
How do I repair indesit IS60v door latch
Get on the manufactures web site and contact them through customer support and they should be able to guide you through the process. The link is most likely at the bottom of the page.
Apr 27, 2014 | Indesit Is60v, Is60vexpai, Is60vnl Tumble...
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
Fitted a new belt to indesit is60v tumble dryer, worked for a few seconds and now does'nt work at all, just makes a buzing sound?
Check that the belt has not fallen off ...does the drum turn by hand easy if so then its fallen off .Motor could also have jammed....
Feb 10, 2011 | Dryers
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
Indesit IS60V tumble dryer runs but doesn't heat
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Apr 19, 2010 | Indesit WA 115 Front Load Washer
Help! My indesit IS60V tumble dryer is banging and dancing
Have the rear bearing and shaft checked. Had same problem briefly until it stopped all together. When I looked at it, I found that the drum rear shaft had worn through the bearing and had been riding on the rear panel. This caused the rear panel, being thin to wear through the shaft until it sheared. This could be repaired by replacing the bearing and rear shaft for around £30 but in my case I'll need to the check the motor isn't burnt out too.
Apr 12, 2010 | Dryers
Indesit is60v tumble dryer is not spinning although still heats, would this need a new belt?
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts from How to Repair Home Appliances
Jan 18, 2010 | Dryers
How do i replace drive belt on an indesit is60v tumble dryer please
Sep 09, 2009 | Dryers
Indesit is60v dryer
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Nov 30, 2007 | Dryers
Indesit WA 115 Front Load Washer Logo
661 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
