Question about Toshiba SD-43HTS System
Protection Error when switching on SD-43HK
When I switch on the DVD player an error flashes across the screen with PROTECTION and it then switches its self off. Is there a way this can be fixed??
  • 1 more comment
  • Anonymous Nov 22, 2007
    i have the same problem with the dvd home system.you turn the dvd on and protection warning glides across the display and then turns itself off. very annoying and dont know why its on .ive used this player twice.is there any way i can fix it ? thanks
  • Anonymous Jan 07, 2008
    protection was coming on as soon as it was switched on, i thought it was a dodgy Disk so opened up and removed, but fault still apparent.
  • Anonymous Feb 05, 2008
    I have the same problem. I concur with all other posts, very annoying. I take it this is a common problem with the SD-43HTS. Has Toshiba done anything regarding this problem?
Protection issue is common with this system.very annoying especially having not to use it for long before this fault develops.everyone is complaining about this protection problem
Posted on Sep 20, 2007
    President:
  • 3,130 Answers
You will need to get a service manual and trouble shoot what amp. circuit is defective. if you have no solid state printed circuit board experience, you really should take this unit in to a repair shop and have it estimated. There is no quick fix for this unit. Good Luck.
Posted on Mar 16, 2007
I just bought a canon sd1300 and when i put the sd card in the screen says memory card error
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Dec 13, 2010 | Cameras
I PLACE MEMEORY CARD INTO CAMERA AND IT COMES UP SAYING ERROR AND THEN CARD LOCKED AND A FLASHING CARD SIMBLE
Hello
Kind regards
Andrea
Sep 05, 2010 | Samsung Digimax 301 Digital Camera
How do I format the card when it says card error on screen? I can not get the screen to change with the menu button
Hello
Kind regards
Andrea
Aug 27, 2010 | Konica Minolta DiMAGE 7Hi Digital Camera
WRITE PROTECT ERROR SCREEN
Hello
Kind regards
Andrea
Aug 23, 2010 | GE A730 Digital Camera
I have write protected error in my sd card 2 gb
HI
Take off the write-protection on the SD card (a small switch on the left side cards with the inscription LOCK)
Aug 14, 2010 | SanDisk Memory Media
Memory card error displayed on screen
Hello
Kind regards
Andrea
Aug 13, 2010 | Pentax Optio S5i Digital Camera
Write protection
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!
Jul 18, 2009 | PNY 2GB microSD Memory Card
"Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
Jan 18, 2009 | Audio Players & Recorders
USB IS WRITE PROTECTED HOW DO I REMOVE THE WRITE PROTECTION SO I CAN USE THE FLASH DRIVE
It depend on the flash drive.
First, the easier, check if there is a tiny switch in your flash drive. You can easily change the switch position.
Second, if no switch, it means you have "error" problem with the drive. You can download the software in the producer's website, or you can contact the producer and they might give you the link to download it.
Third, if no software offered by the producer, then you have quite big problem. Many have this problem if they unplug the driver unsafely. One possibility to remove the write protection is going to the "Regedit" and change the value of :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
go to ‘WriteProtect’ and change the ‘Value Data’ to ‘0’
Jan 13, 2008 | iLO (2 GB) MP3 Player
Toshiba SD-43HTS System Logo
753 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
