Question about IBM ThinkPad A30 Notebook
0190: critical low battery error
I have an IBM think pad unit that won't boot into windows. If I have the battery IN then it would start then just shut off immediately. If I connect to AC power and remove the battery then it starts up with IBM logo then after few seconds, it gives me 0190: critical low battery error. Thanks
  • IBM Master
  • 2,075 Answers
You shouldn't start your thinkpad with AC in and no battery. I'd suggest to replace the battery.
Posted on Jan 24, 2018
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
When old IBM Think Pads fail to boot it is usually because the CMOS battery has worn out. It is very easy and inexpensive to replace. Youtube has numerous videos showing how to replace it e.g. https://www.youtube.com/watch?v=8ZI-8Q2j-zQ
SOURCE:
How do i fix my ibm think pad with 161-163 error on start up What's your problem?
you need a new clock battery (on the motherboard), then reset time and date and after a few turn ons it should be fine
Oct 19, 2012 | Computers & Internet
0190 critical low battery error
push the power button at the same time with thinkpad button, and fast press F1 key.
you should need to do this 3 times to fix the problem.
May 14, 2011 | IBM ThinkPad T20 2647 Notebook
WHEN I START MY IBM THINKPAD A31, I SHOWS THE IBM SIGN AND THEN IT SAYS 0190: CRITICAL LOW BATTERY ERROR SEE IF YOU COULD HELP ME. THAN.
Yeah it's a pretty common problem with certain ThinkPads.
Here's a good place to start if you wanna know how to fix yours.
I'd recommend signing up for the forums and posting your question there since you'll get a lot of specific support from fellow ThinkPad users ;)
Hope this info helps!
Oct 09, 2010 | IBM ThinkPad A31 Notebook
What should i do for 0190 critical low battery erroe in ibm r52 laptop
Normal 0 If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Oct 06, 2010 | IBM ThinkPad R52 Notebook
Ibm think pad r32 0196 critical low-battery error will boot up then turns it self of
Fail safe in the battery has engaged. See if the computer will start without the battery, using just the power supply. If you can get it started then put the battery in and see if it will charge or reset the fail safe. Give it about an hour, then shut it completely down and restart it with the battery in. If it won't start at this point, then you will need a new battery. Also change the CMOS battery inside the computer
Change the CMOS battery
Nov 04, 2009 | IBM ThinkPad T20 2647 Notebook
Ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646&current-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
Nov 05, 2008 | IBM ThinkPad T20 2647 Notebook
IBM Thinkpad T21
This is a common problem with the T20 series Thinkpad. The problem is with the power management chip. Unfortunately, you will have to replace the motherboard to fix it. Since these are a bit on the older side, you can get a motherboard off Ebay at a reasonable price.
Aug 04, 2008 | IBM ThinkPad T21 Notebook
To solve problem on my IBM \Think Pad T2 2 PC
Error 00174 is a configuration related indicating the bios/cmos settings are incorrect. This usually occurs when the cmos battery is in need of replacement.
Get that battery replaced.
Dec 19, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
i know what the error is what it is is a wire labeled "MAIN" has disconected to fix it you need to put the wire back into the tiny slot in right bottom corner of the right hole
i had the same error and just fixed it like 2 minutes ago it now runs perfectly
Dec 17, 2007 | IBM ThinkPad T20 2647 Notebook
Open Questions:
IBM ThinkPad A30 Notebook Logo
1,634 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
