Question about AT&T 5840 Cordless Phone
Handset Searching for Base
I have a problem with this AT&T 5840, The Handset for no reason finds itself searching for the base unit. There are times I'm right next to the base and I will pick it up and press the button and it will start to search. After searching sometimes it finds the base some times it goes to a blank screen and never returns until I put it in the cradle. It's a nice looking phone but this is become a real proble If I dont get a solution in the can it goes.
5 Suggested Answers
SOURCE: handsets won't hold charge and have no base subscription
smash it into little pieces! That's what I'm doing with mine.
Posted on May 31, 2008
  • 1340 Answers
SOURCE: the cordless handset for my
For now simply try unlugging everything from the outlets for about minutes.If that does not work,I will locate the info tomorrow about some other possibilities.Different makers have different ways to access the program part and I will look for what may cause it.Good luck,Greg
Posted on Dec 25, 2010
remaker
  • 449 Answers
SOURCE: tring to add a handset
The process is called "Registering."
From another fixya post:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Posted on Mar 22, 2011
SOURCE: I need to de-register an
When the handset is searching for the base, click the new button, then enter the 15 digit base ID number into the handset.
Posted on Jun 04, 2011
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
Tring to add a handset to a att 5840 base!
WAIT!.
use.
Mar 21, 2011 | AT&T 5840 Cordless Phone
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Mar 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
Handset reads "searching"
The reason the handset says "Searching" is because it can not find its Base Station. What handset works with a notebook? I had not heard of such a thing.
Sep 15, 2009 | Philips VOIP3211S/05 IP Wireless Phone
Phone on base showing it is "searching" for base.
check to see if the power cord is properly plugged in. You may have the phones on the wrong cradles, this wil cause them to search.
Apr 29, 2009 | Uniden Cordless Phone
Base station and units all say 'searching'
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Dec 22, 2008 | Philips DECT 2252S Cordless Phone
Searching is displayed on handset and Y icon is blinking, looks like a twig sign, have tried move closer to base station, base station is on reset unit restart handset reg, have tried all but gets to...
Turn base around and find the area which says pager/registration. Push this button after you set internally the handset registration.
Menu/H set settings/Reg. Handset
Dec 03, 2008 | Lands Phones
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
Jan 28, 2008 | Uniden Cordless Phone
Open Questions:
AT&T 5840 Cordless Phone Logo
54 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
