Question about Acer Aspire 5610-4648 Notebook
I reboot my laptop when it was rebooting it stop and dont respond i turn it off using the start button when i start it it said that BOOTMNGR is missing press ctr,alt,del to restart itry many times but nothing happen pls.. help me
    President:
  • 2,110 Answers
Your Operating System might be corrupted try to install windows Again...
Posted on Dec 14, 2008
I am self cleaning my wall oven. I have an error message with F 10 but the oven will not respond when I push stop.
Flip the electrical circuit switch for your oven after 5-10 minutes watch what it does when you do. After it reboots follow normal procedures should respond properly. If not push your stop button keep pushing on it for at least 15 30 seconds this should clear it. If not flip the power switch again then watch it as it reboots when you turn it back on it should respond. What has happened is you have knocked the program out of operation mode. You need to clear that is why you need to shut the off to oven then start again.
Nov 19, 2017 | Ovens
Factory reset lenovo g580
Step 1:
There are a variety of reasons you may need to reboot a Lenovo laptop. These can include the installation of a new program, the dreaded blue screen of death or to free up memory that has been hijacked by a program that is now closed. There are three ways to reboot and all are simple to accomplish.
Click on your start menu button on your screen. Click on "Shut Down" or "Turn Off Computer." Click on the drop down box if you are running a version of Windows before XP (such as 2000 or 98). Select the "Restart" option and then click "OK." On XP or later versions, click on "Restart." The laptop will then reboot. Press and hold down the "Alt," "Ctrl" and "Shift" keys simultaneously. This will bring up the Task Manager. Pressing and holding the same keys again will force the computer to shut down. Press the power button to reboot the computer. This feature should be used when the mouse has stopped working and you cannot access the start button. Hold the power button in the "Off" position for approximately 5 seconds. This will force the machine to shut down. Press or slide the button again to reboot the laptop. Use this process when you get the "blue screen of death" or the computer is not responding to either the mouse or the keyboard.
Feb 22, 2013 | Lenovo Computers & Internet
My toshiba laptop keeps freezing. we just got a new battery for it. This has never happened to it. Anytime i try and do something it freezes up and says its not responding. But when i try and hit, ctrl +...
WOW!!! This could be from many things, too many to sort through in this form. Reboot your pc and enter the BIOS setting. Go to the exit screen to select ALL DEFAULT SETTINGS. Save and exit. As the pc starts to reboot, press F10 (yours may be F5 or F8) to enter boot menu, select "Last known good start (boot)" If your system encounters the same problems, you may need to reinstall your os/apps from your recovery sector.
Please post your results and we will continue if needed.
Good Luck
C2Solutions
Oct 22, 2011 | Toshiba Computers & Internet
How can i reboot my acer laptop
Press Start(ORB at bottom left for vista/w7) and if you're on windows 7/vista, there should be a list button on the bottom right side of the start menu saying "Shutdown"(windows 7) and "Sleep"(Vista), click the list and click Reboot.
On XP you need to click the Shutdown button and before you click shutdown instead click Reboot(Green button If i recall correctly).
Jul 15, 2011 | Computers & Internet
After 2 yrs unused have decided to run in new dell
Did you plug in the scan unit and then installed the software?
If you did you will have to unplug or turn off your scanner then uninstall your software.
Reboot and the with the scanner turned off reinstall the software. If the install asks you to plug in your scanner, turn it on. If it asks you to reboot, then reboot. After rebooting, turn on the scanner then start the Easy Scan Utility. This should work.
It worked for me.
Jan 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
I can't open my Compaq Presario c700 and I got this msg: bootmngr is compressed.
Boot from your Windows CS and select Repair your Computer -> Command Prompt, execute the following commands:
bootrec /fixboot
bootrec /fixmbr
Reboot.
Dec 27, 2009 | Compaq Presario 700 470024-192 Notebook
Virus
Turn it off and back on again, that is rebooting..
You can either do it by useing the start button then shut down, or holding the power button till it shuts off...
But the 2nd choice is last resort effort
Sep 16, 2009 | Acer Aspire One PC Notebook
Computer will not respond and firewall off will not come back on
You most likely have a virus or spyware, start up in Safe mode and run msconfig from Start, Run uncheck anything that looks suspicious then reboot. Then when the computer comes back up Start, Run, type CMD and then type the following command:
rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
you will need to reboot the computer but that should get your firewall back up and running.
Hope this helps,
David
Feb 17, 2009 | Acer Aspire 4720 Notebook
Laptop needs rebooting
Im using the advent 4211-b and its flawless.small,light ,looks good has all you need built in and also has choice at startup windows or recovery.cant fault it.if you cant reboot.press power ,get as far as you get ,press and hold power button til switch off press power button again to restart(boot)if youre already in windows and cant shut down or reboot do the same.as long as you dont turn off and unplug no damage to the system will occur.
Jan 04, 2009 | Computers & Internet
Toshiba Laptop Keyboard Not Working
pls dont use your notebook yet, since there are still moisture in it. try to use a hair blower but place the hair blower at least 2 feet away. you dont want to melt the plastic in your notebook. blower it for 20minutes then try to turn on your computer. if it still does not work. I suggest to bring it to the service center of your notebook.
Dec 22, 2008 | Toshiba Satellite M100 Notebook
Acer Aspire 5610-4648 Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
