Question about Smeg SE250XUK Stainless Steel Electric Single Oven
Oven will not switch on
I have a SMEG single oven SE210NE. The oven will not switch on. All Iget is the letter 'A' switching on in the display. The oven light bulb does not switch on. I have changed the thermostat but nothing changed.
My Smeg oven will not work either. All I get is an "A" on the display, the clock has disappeared and as a result the oven won't come on. I see from other postings here I can bypass the clock so that the oven works again - can anyone advise how I do this?
Posted on Aug 05, 2010
  • 20 Answers
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Posted on May 23, 2009
  • granttaylor2 Dec 25, 2014
    This is something, a qualified person should do. The digital clock has spade connectors on the back, a live connector in and out(also a neutral connector). If you know what you are looking at, a "piggy back" connector, which connects the live-in and live-out together, thus bypassing the clock. A simple procedure for someone who knows what they are looking at. Remember this is only when the digit "A" and nothing else is displayed on the clock(different to "a- auto", where clock IS displayed as well). In this case, oven will not work either, as clock needs to be set.
  • Smeg Master
  • 3,463 Answers
Make sure timer is set to manual if it has one., it will not work on auto.
plz rate this solution.
thanks.
Posted on Dec 14, 2008
Can you help me zanussi zcm610x cooker how can i bypass the timer
Posted on Jun 03, 2012
  • Chermaine Lowies Jul 26, 2012
    did you get an answer how to bypass
My oven wont work it is a smeg model no suk91mfx5 the fans and lights work but it wont heat up theres 4 heating elements on this cooker
Posted on Jul 15, 2010
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
  • 1462 Answers
SOURCE: light bulb
for most smeg, the bulb cover just unscrews as does the bulb and the bulb is a heat-proof small edison screw type
Posted on May 07, 2007
We need to slam the oven door to switch off the intenal light and make the oven work?
cleaning your oven door switch might help but I would consider replacing the switch. The switches are sealed and cleaning does not work well.
http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Smeg F65 Stainless Steel Electric Single...
It is brand new oven, the light is permanentl on and the function nob dose not function
Don't even try adjust or open any part of the unit. Take it back to the dealer or you will invalidate your warranty and that is not worth it. Let the dealer worry about it.
Feb 21, 2011 | Smeg SE210NE/1 Oven
My light bulb keeps blowing i have replaced it twice with a 25watt and as soon as i switch it back on the bulb blows
Perhaps you have up to 240 V on the lamp socket and you are installing a 120V bulb. Check for wiring faults, especially an open neutral or ground connection in the oven. If the lamp socket neutral is connected to the neutral on a lower-resistance device on the other leg, but the wire connecting these two items is not connected to the power cord neutral, the voltage across the bulb will be more than it can handle. In this scenario, the other device (heating element, timer, or whatever) will probably not work or will work poorly after the bulb blows.
Nov 04, 2010 | Smeg SE210X/1 Stainless Steel Electric...
My smeg oven is turning on automatically and we don't know how to stop this
The contacts have welded close on the switch that controls whatever element that comes on automatically. Replace switch
Jun 27, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg cooker 8 function model
Hi.
Sounds like you have a faulty thermostat, the contacts could be sticking.
New stat would seem to be called for.
Nov 21, 2008 | Smeg SE399X/5 Stainless Steel Electric...
SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Oct 18, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven diplaying an "A" in display
I have had the same problem today - trying to change to day light saving time - can you help me too if you find out.
Sep 25, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Light bulb
May 07, 2007 | Smeg SE250XUK Stainless Steel Electric...
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
2,754 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
