Question about Sony Ericsson W200i Cellular Phone
Whenever i turned on my w200i phone, the backlight just blink and blink.. and will not continue to to go to the display, just light that blinks.. and will not turned off unless i take off the batteries.
  1. This problem may be caused by harmful software or games which sonyericsson is not supporting.I had this problem year ago. i solved it byreinstalling mobile operating system i found it google..Search for R4JA011
  2. R4JA011
  3. R4JA011
  4. R4JA011 these are operating systems for W200i good luck.
Posted on Dec 14, 2008
I have a Bravia-Kdl40W580B led tv . I have backlight but no picture. I replaced all three boards. I did a firmware update . I have backlight and the LED light is blinking slowly and its blue
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 15, 2016 | Televison & Video
Philips 40inch LCD 40PFL7705DV/F7 When connected to power, it tries to crank for 15 sec and turn off by itself. This repeats. Back light is on while it tries to turn on.
Blinking codes details of many popular brand TVs are given. Surf the site with patience.If blinks continue without any pause, the main board is faulty.
  • Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Feb 29, 2016 | Philips Televison & Video
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
The handset display cannot be seen, the backlighting is working. A580IP handset.
the display unit is not functioning... it is either the problem with the bus(wires) connecting the display and the board, or the problem with the display IC...
backlight is an ordinary led light, it will continue to work whenever there is a power supply to it...
Aug 09, 2010 | Siemens Gigaset A580 IP Cordless Phone
Power goes out and cant turn unit back on. Green light continuously blinks, it turns on by itself twice and now green blinking light is for ever. help...
Unplug replug about an hour later,if the same problem than ur backlight video board it dead.Need it replaced.
Dec 10, 2009 | LG 32LC7D Television
Turn on the phone
This is a longshot but worth a try.
Take the back off, take the battery out and run a hair dryer on medium over it for about 30 min or so until you see no water spots on the screen.
Service locator for India:
http://www.sonyericsson.com/cws/support/key.SupportSubDepartment.Service%20locator?cc=in&lc=en
hope that helps!
Jan 29, 2008 | Sony Ericsson W200i Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
105 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
