Question about Nikon Cameras
L18 No images in memory when playing back
Just got the L18. Have tried with a 2GB SD card, and also without (just using internal memory). Using 'easy-auto' mode (to keep it simple), I have tried numerous pictures. The camera takes the pic, but playback shows: 'No images in memory'. Bad camera, or am I missing something? Owners manual not indicating the problem. Thanks
  • c1carroll Dec 14, 2008
    nevermind...my mistake. With this camera, you need to hold the shutter button long enough for full focus to complete, before the picture gets taken. Seems a bit long, but at least I now know it works.
Solution was simple. I hadn't held down the shutter button long enough to fully capture the shots.
Posted on Dec 15, 2008
I have a Pentax Kx and recently bought an 8Gb memory card. However I get a lot of blank images with the error message 'image cannot be displayed' especially if I use the continuous shooting mode....
Dear,
First of all you need to confirm that what kind of memory card your are using. The officially recommended type and brands are here
Toshiba *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
Panasonic *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
SanDisk *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
rather than these might be problematic or not compatible...
Check this first
Best of luck!
Jul 10, 2011 | Pentax Cameras
I just got a kodak slice 14 megapixle.. with out a memory card it only takes about 20 pictures.. where is or how do I find out the internal memory,... It looks like even if I use a 4 gig micro card. the...
Depends on the size of the images - if you are using best quality and large size, the number of images will decrease accordingly. Look in the manual for the correlation. BTW, the internal memory and the SD card are not the same thing.
Jul 09, 2017 | Kodak SLICE Touchscreen 14MP Digital...
I found one in my desk at work. It's missing a memory card thus no one is using it. What kind does it take? Can it be by any brand?
It can take a SD memory card or SDHC memory card, recommended brands: SanDisk, Toshiba and Panasonic from 128 MB to 4 GB capacities.
The manual and other information for the Coolpix L18 is available from Nikon: http://www.nikonusa.com/Nikon-Products/Product-Archive/Digital-Camera/25596/COOLPIX-L18.html . The list of memory cards is on page 91.
I hope this helps.
Jan 07, 2011 | Nikon COOLPIX L18 Digital Camera
To get the camera to play from 2gb to 8gb.at 2gb it will play about 40 mins.
its because you have the camera set to store the video in the internal memory not the SD card you have to change the settings so it will save into the SD card instead of the internal memory
Dec 09, 2010 | SanDisk 8GB microSDHC Memory Card with...
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
Lens will not extend, screen is black, ''no image'' message
Make sure you are using a 2GB SD card or smaller. Make sure the camera is set for Camera Mode not Playback. That is the switch that shows a camera or a square with an arrow in it. When the camera is in play back the lens will not come out until the camera is set for camera mode. The no image in playback will occur every time you use an SDHC type memory card. Formatting the memory will not make the camera take the SDHC type cards since it was never designed to use them.
Nov 23, 2009 | Cameras
Memory card contains no images after camera turned back on
Are you able to access the images using a card reader on your computer ?
Apr 18, 2017 | Nikon Cameras
Internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Jun 27, 2008 | Kodak EasyShare C875 Digital Camera
Cameras Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
