How do i flush the toilet by hand until i get it fixed
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
SOURCE: When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
