Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
How to open front panel of washing machine?
Hi -- I have a GE WSM2480DWW Spacemaker washer/dryer. Am trying to fix the lid switch but need to get at it. I think I need to open the front panel but can't figure out the trick. Can you possibly help? Thanks so much for your help! Thomas.
  • ArunagiriGT Feb 15, 2009
    I have a Samsung wash machine. Same problem exists in Samsung manual as well. No instruction about opening the front panel. Let me know if any one find solution for it.
I think you use a putty knife and slip it between the lid and the front panel and depress some clips that hold it on.  I'm looking for the same answer and that's all I've been able to piece together so far. The GE manual is worthless on this point.
Posted on Oct 15, 2007
Ok on the GE spacemaker ,it's in the back.
there are two screws that you should open and then the front just comes off.
i tried the knife option at first and just ended braking the plastic clip.
Posted on Mar 15, 2009
SOURCE:
Washer wont drain or spin. Thewasher will agitate.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 24, 2011 | GE WSM2480DWW Unitized Spacemaker Washer...
Water is not draining?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
How do I remove the front panel of a GE SpaceMaker washing machine?
Washer panel can be removed by removing the 2 screws at the bottom and push the panel down then pull forward.
Feb 26, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
My ge spacemaker is about 6yrs. old it will not spin or dry clothes how do i fix it w/o paying a repair man
i would first check the lid switch it could have a broken wire on it. here is the picture of where it is250 located. the part number for it is WH12X955. you could also check the direct drive coupling which is located on the motor shaft and consists of 3 pieces. this coupling takes the place of a belt. your machine does not have a belt on it. the coupling part number is 285140. hope this helps.
Nov 07, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
My GE Spacemaker Dryer Model WSM 2700 DA no longer heats up. HOw difficult is it to change the heater element or is that the problem? P.S. I have cleaned all the vents out with very little material found.
either the heating element, hi-limit switch, thermal fuse (on some), cycling switch,or a burned neutral power wire in the unit, first, make sure you have 240 volts input power
Oct 22, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WSM2480TBAW Spacemaker Laundry, Won't Drain or Spin
you need to remove the slanted panel between the washer and the dryer. There will be 2 screws holding the top of the washer to the cabinet. Locate the screws on the back edge of the washer top along with the 2 brackets that hold the top.
Once the brackets have been removed, the washer top panel will pull toward you and lift off of the cabinet. You will be able to see the lid switch and test it. If you are testing the lid switch for continuity, remamber to activate the switch while testing. If the switch shows an open circuit, replace the switch.
Please let me know if this hhelps you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | GE Spacemaker Washer and Dryer Electric...
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Pump leakage
yes but the coin trap just may be misaligned try to open it and lock it back in place...let me know
Sep 27, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge spacemaker
check power at the receptacle make sure you have 240v
May 11, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer/Dryer
lincoln, there should be two clips on each side just below the top. Take a puddy knife and push in on the clips. The front panel should release and pull foward. Catriver..post back.
Mar 15, 2007 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
1,779 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
