AFTER CLEANING / SPRAYING THE ENGINE COMPARTMENT THE LIFTGATE AGAR LIGHT COMES ON AND THE DOME LIGHTS WILL NOT GO OFF. WHERE IN THE ENGINE COMPARTMENT IS THE WIREING FOR THE LIFTGATE I BELIEVE I GOT SOME ARMORE ALL ON IT. THANKS SO MUCH FOR YOUR HELP. TOM.
The problem is the lift-gate ajar/courtesy light switch that is located on the left and right latch assemble of the lift gate, they stick and cause this concern, there are numerous technical service bulletins from Ford about this, have replaced at least 100. PS, washing the engine had nothing to do with it, u can try using spray lube on the latch's and open and close the gate repeatably to see if the switch un-sticks.
The liftgate lamps
Courtesy/map lights
The courtesy lamp supply voltage circuit of the body control module (BCM) supplies battery positive voltage to the dome lamp, the liftgate lamps, and the map lamps. When any door is opened, the door jamb switch contacts close providing a door open input to the BCM. The BCM then provides a ground to the interior lamps with the switch in the AUTO position. The interior lamps receive a ground at G401 with the switch in the ON position.
Important: If the liftgate is opened after all the modules go to sleep, the dome light will not come on. The liftgate ajar switch input to the BCM will not wake up the BCM once it has gone to sleep, so the dome light will not come on. Once the BCM gets an input to wake it up, from remote keyless entry (RKE) or a door handle, the dome light will turn on when the liftgate is opened.
If the driver inadvertently leaves any interior lamp ON, the BCM will turn it OFF after a 20 minute time-out.
The courtesy lamps will turn OFF immediately if the ignition switch is turned to the ON position or approximately 20 seconds after all doors are closed.
The courtesy lamps are controlled by the body control module (BCM). Inputs from the dome lamp switch and the door ajar switches are monitored by the BCM. When a door ajar switch is closed, or the dome lamp switch is turned to the ON position, the BCM supplies the B+ for the courtesy lamps.
With out a factory Tech2 scan tool or equivalent an knowing how these systems work ,you best bet is to take your vehicle to the dealer or some other ASE certified repair shop !
How much does this fix cost?
