Question about Nokia E50 Cellular Phone
E50 doesn't recognise names for text mesages but does 4 calls
When i get a text the name of the contact does not come up unless the number is entered in my phone-book as +35386......(Ireland) insted of 086...... when i do change a number to this, it is not recognised when i receive a call but the texts are fine.
  • driordan16 Dec 14, 2008
    I cannot find any display options in messages or contacts that can help with this
    Scholar:
  • 145 Answers
Change the display option, it will show names
Posted on Dec 14, 2008
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
The number is saved in my contacts but when i get a text from them it doesnt have their name
if it is saved with different names in phone and sim it doesnt show the name once check it and try...
Nov 10, 2011 | Nokia 6121 Classic Cellular Phone
Msgs from 'unregisterd contacts' when names ar registerd already
This often will happen for interstates or overseas contact, when you enter your contact number without Country and/or Area code and the received number is 'different' like completely specified (or the other way around):
1). On your contact, Smith number is 0123 456789 but you receive +61 3 123 456789 (this is the most likely scenario for you as you can reply properly)
2) your contact, Smith number is +61 3 123 456789 but you receive 0123 456789 (as an example, they are calling using VOIP and can specify the number they transmit)
Solution is to look at you phone log and enter the number EXACTLY as received even as an additional number.
Hope it helps let me know how you go!
Jan 24, 2010 | Nokia N97 Cell Phone
Sony Ericsson Satio not displaying contact name when receiving a text, only displaying their numbe, despite me having their name & number stored in my contacts list. When making and receiving call, and...
there may be promlem in ur contact setting so try this.....
go to contact option then open setting
there may be many options like contact view e.tc
u choose in these option "name and number"
Nov 10, 2009 | Sony Ericsson Satio Cell Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Cect P168 contacts problem
Restore the iPhone.
Thank you, Apple Care Technical Support
Jun 30, 2008 | Apple iPhone Smartphone
I want to program a new number into my old A900 Samsung phone to replace my wife's old phone.
Hi
Surprsingly u never mentioned the name of the network which u r using. Please mention the CDMA server's name.
Thanks.
Supriyo DG
Jun 19, 2008 | Cell Phones
Samsung d900i
Create contact (Menu 2.3)
Use this menu to add a new contact to Phonebook.
Storing a number in the phone’s memory
1. Select Phone.
2. Change the settings or enter information about the
contact:
First name/Last name: assign a name.
Mobile/Home/Office/Fax/Other: add a
number in any category.
You can change the number type, or set the
number as the default for the contact by
pressing <Options> and selecting Change
type
or Mark as default number.
Email: assign an e-mail address.
Graphic ID: assign a caller ID image to alert
you to a call from the person.
Ringtone: assign a ringtone to alert you to a
Group: assign the number to a caller group.
Birthday: enter the person’s birthday.
Notes: add a memo about the person.
3. Press <Save> or [ ] to save the contact.
Storing a number on the SIM card
1. Select SIM.
2. Select New or Update.
3. Enter information about the contact:
Name: assign a name.
Phone number: add a number.
4. Press <Save> or [ ] to save the contact.
Mar 05, 2008 | Samsung SGH-D900 Cellular Phone
Contacts
i don't use 1-000-000-0000 and my caller id works fine with text and calls
Sep 22, 2007 | Samsung UpStage SPH-m620 Cellular Phone
Nokia E50 Cellular Phone Logo
125 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
