Question about Craftsman 4 Cycle Blower/Vac
Craftsman leafblower running worse
2-year old craftsman leafblower still starts fine but doesn't have the power it once did. Rattles loudly (like metal on metal) when idling. Starting to spray oil from the case. Is it worth repairing?
    Scholar:
  • 149 Answers
Check the exahust screen (if fitted) for blockage. or exahust port...If it is clean port and or screen and use correct type/ ratio mix.
Posted on Jan 15, 2009
Briggs& Stratton 14.5 starts and runs. Has a loud knock. This did not begin a while back then get worse, it simply started out loud and is still loud. I was certain it was a connecting rod so I bought a...
The loud knock can mean that the connecting rod bearing may be going bad. The engine should be torn apart to see if this is the problem. The lobes on the camshaft should also be checked as well.
Sep 20, 2013 | Craftsman Garden
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
Microwave won't start but rattles when close door.
It is possible you have one or more door switches that are bad and need replacement.
May 05, 2012 | GE Microwave Ovens
I have an old craftsman leafblower it will run but seem to strian to run at full speed n I have rebuild crab too new fule line new gas check compression it abt 90 lbs
Most likely suspects: 1) Carbon in the spark arrestor screen. 2) Carbon in the muffler. 3) Carbon in the exhaust port.
To prevent this issue in the future you should use a 50:1 ratio for you fuel mix.
Hope this is helpful,
Dolf-
Nov 13, 2009 | Garden
10 year old Craftsman Lawn Tractor won't start
That's really strange. The low-speed fuel adjustment screw may be set way too rich, but that doesn't seem likely. With the air filter off, look at the choke plate if possible as you advance the throttle and see at what point the choke closes. Back it off till the choke opens and then put the filter back on and try to start it at that setting. Another thing that could cause too much fuel is if the adjustment of the carburetor float is off, causing the fuel level to be too high in the carb bowl.
Aug 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
CRAFTSMAN LEAFBLOWER TROUBLE
After you do the above, try to clean out the fuel line. It may only be letting in a small amount no matter the throttle control.
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman gas leafblower
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Nov 16, 2008 | Garden
Craftsman 4 Cycle Blower/Vac Logo
328 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
