Question about Dryers
Can't take the back of hotpoint CTD85
Have F10 error, but need to take tha back off. have taken all the screws out but it still won't come away, seems to be held down by the top
So how did you do it??
Posted on Dec 03, 2009
My son worked it out, we had taken it off properly but didn't know what we were looking for.
All sorted
Posted on Dec 15, 2008
Pressed reset button on left hand therm0stat dryer runs but still error code f10 elements not getting warm
I found this, an answer already posted on Fixya.....
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Dec 12, 2013 | Hotpoint Dryers
Timer counts down too quickly
Possible there is fault in the timer unit . check for loose connections or loose joints to the unit, if not this needs a replacement.
Jan 12, 2013 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Faulty control board hotpoint ctd85
You can remove the panel and check for fault in the connectors and the line to the display, use a hair dryer to warm and dispel any moisture on the board and panel. If there is no result then the panel has to be replaced.
To remove click : control panel
Jul 26, 2012 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
I keep getting error code F-14 on Hotpoint condenser dryer model CTD85
Hi.
F14 means that control board does not sense that machine is heating:
F14 - A fault with the water heating has occurred
When you get F14 the fault is usually either the thermistor or the heating element (electric dryer). Both parts are tested removing the part from the dryer and reading impedance at the part contact. If the part returns infinity, then the part is defective. If you need to contact a qualified technician use the phone number listed on your owners manual or check Hotpoint website.
Regards.
Ginko
Sep 20, 2011 | Dryers
My hotpont tumbledryer keeps flashing up f11 its a hotpoint ultima ctd85 pls help
Fault code F11 means that the pump is not working,check the pump connections and the pump itself.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Dryers
How do you take the back off a Hotpoint Ctd85 tumble dryer . I have taken all the screws out and the top of the machine and the two bottom corners are still holding the back on tight. I cant see anything...
most dryers you cant remove the back, you remove the front face then the top, then drum and this is how you get into the rear dryer area
Oct 31, 2009 | Dryers
F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
Feb 02, 2009 | Hotpoint TDL15 Electric Dryer
CTD85A dryer showing F-10
You have to remove 2 screws that secure the heater element to the rear cover, there you will find the thermostats located.
Be careful not to damage the element as it is very fragile, and is easily broken.
Plz rate my solution.
Thanks
Jan 14, 2009 | Dryers
Ctd80 hotpoint dryer error code f10
Apparently a common fault on these indicit based driers.
it worked on mine
Oct 08, 2007 | Dryers
Dryers Logo
189 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
