Question about Zanussi FLA1201W Front Load Washer
Water leaking and dial spinning
Two problems water is coming out of the drawer for washing powder and the lettered part of the cycle selection dial is turning separtely from the dial so I don't know what programme I am selecting. Don't know if the problems are connected. Cheers
  • Anonymous Mar 21, 2014
    Water leaking under the machine but only when on spin
    President:
  • 1,462 Answers
Unconnected faults. does water come out of drawer when filling? if so fault is a blockage in hose down to tub from drawer or drawer may need cleaning if fault happenns on rinse. fault on knob is broken inner knob and poss cam as well
Posted on Mar 20, 2007
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 10, 2013 | Washing Machines
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Water leaking out through powder drawer
please take your drawer out and give a good clean also look inside when drawer is out and clean there as well good luck regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Feb 16, 2008 | Whirlpool AWM8143 Front Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Water leaking (Aquarius 1200)
don't think using quick wash should make a difference as water intake is the same take drawer out and wash thoroughly especially the rinse compartment. if gunged up the water overflows the compartment and leaks down the front. otherwise, you may have a blockage in the hose from the drawer to the tub. take top off, remove this hose and clean disconnect from mains when you do this
Apr 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Zanussi FLA1201W Front Load Washer Logo
151 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
