Question about Dell Dimension E521 PC Desktop
Startup repair failed. cant get to startup screen
Yesterday my main comp was acting slow so I shut it down and tried to reboot. It went to startup repair (windows Vista) and went through the process of trying to repair itself. It said that it could repair and to call my system admin for assistance. I didnt get a recovery disk with this comp so what can I do to resolve this problem other than getting a new comp?
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    You will need to go to support.dell.com and register yourself and your computer using the Service Tag number. Once you have done this you can request a restoration DVD or Windows DVD for your particular system.
    There shouldn't be much of a fee, shipping and the like. If you end up with a Call Center in a foreign country and are not getting anywhere fast, hang up and call again. Do this until you have a successful agent who understands your need.
    On your system there should be a hidden restoration drive partition. When you access the Repair section and it advises you it can be repaired there should be a prompt or clickable icon to start the repair. I've personally never heard of the need for a separate disc. But, Dell could have done this on new systems, we all thought they were getting away from this.
    By the way, to speak with an American Tech will cost you $14.95 today. And, this is about your best option.
    Regards,
    Worldvet
  • pgmadhav
    pgmadhav May 11, 2010
    Is your windows is a pirated version???
    Scholar:
  • 113 Answers
Did you back-up your important files?, if you did, then you need to reformat your hard disk drive (hdd) and reinstall new system.  but if you didn't backup your important files, ask for help at the service center near you, cause it need another hdd to backup some files.  then if you have nothing to lose on your hdd then go ahead to reformatting. sometimes that error occur when it didn't undergo proper shutdown
Posted on Dec 14, 2008
I have lost my instruction booklet and it has been almost 1.5 years since I have used the notebook. I cannot get it to turn off. It keeps saying Windows is Shuting Down; however, it is still on. Can...
Hi There,
Simply hold down the power button until the notebook shuts down. Then, restart the notebook and it may just boot up normally. If you're taken to a screen with options that include Startup Repair or Start Windows Normaly, try Normaly first. If it won't start, use Startup Repair the next time around.
When you leave a notebook off that long, Windows may have tried to install dozens of updates. You will need to patiently update Windows completely.
Regards,
Selk
Mar 27, 2011 | Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Hello. My name is henry my problme is: yesterday
Hello Henry. Let's begin by resetting it. Carefully lift off the thin, delicate frame around the screen with your fingernail. under there you will find the reset button. With the garmin on, push the reset. This act may solve your problem. If it does not you will have to send the unit into Garmin for a repair. Go to Garmin.com to do that. J.
Jun 15, 2010 | GPS
Windows vista has disappeared from laptop
try putting the recovery disc in the puter for a reboot, and follow directions to allow it to repare itself, i been doing this alot with laptops lately, seems to be the only solution i can do ....shia
May 22, 2009 | Computers & Internet
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
Blank/black screen at power on
This is hopefully a possible fix. I have encountered a similar problem with windows xp and vista. the fix I found that will eliviate this problem and a startup-reboot-startup-reboot... If you have your original windows (xp or vista) CD lounch it like you would do to do a system install. As the installation starts it will show ask you if you would like to do a recovery using the recovery console, just press ESC and go on. Press the F8 to accept the license. If Windows is not completly broke, it will find the original installation on your hard drie. It will ask if you want to repair. Press the R key and windows will reinstall your operating system, without destroying your software or data. After it is done the system will go to the windows startup screen. You will need your windows product key located on your machine or on the original software packaging.
I hope this will fix your problem.
Mar 17, 2009 | Dell Inspiron 6000 Notebook
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Laptop failure
Boot into safe mode by pressing F8 about 10 times during the post screen. Then completely remove your video drivers. Then reboot, into windows normally, go to the Nvidia web site and download the latest graphics drivers for the video card that you have. If this does not solve your problem, then you may have bad video memory on your video card.
Nov 19, 2008 | Medion (40010998)
Blue lines on Display seen.
that is easy just go to rooftop of the building and throw you loptop ok
Oct 19, 2008 | Toshiba Qosmio F25-AV205 Notebook
Dell Dimension E521 PC Desktop Logo
284 people viewed this question
Alun Cox
