Ariston washer dial keeps clicking around - Washing Machines
  • pedropony2 May 11, 2010
    Bit more info plz.
    Is There water still in machine?
    Did it start wash ok?
Shoot it
Posted on Apr 24, 2009
  • 135 Answers
Thankyou for using fixya
Posted on Dec 23, 2008
  • Washing Mach... Master
  • 3,463 Answers
If it has a reset position, indicated by a black spot on timer dial, there can be 3 of them.
Set timer to this position, switch on and let water pump out.
Switch off and reselect prog if it still does the same then you have an anomaly (fault).
you will need to call anengineer.
Posted on Dec 14, 2008
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
Dial keeps spinning
I have an Ariston Margherita AL128 and the same problem happened. The dial keeps on turning and the operation does not finish at all. After skimming through the manual, it occurred to me that it could be the pump that's causing not to drain or spin anymore. Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manual once in a while, it does help! I lost mine but was able to download a copy from the net.
Feb 01, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Washer/dryer stops mid cycle
I have an Ariston Margherita AL128 and the same problem happened. After skimming through the manual, it occurred to me that it could be the pump that's causing not to drain or spin anymore. Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 30, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Hariston margarita a1324 advantage
hiya
dont remember giving assitance before but i'll try and help you if i can. when the machine starts to click around count how many times the doorlock/on off light flashes as this indicates a fault code. it will usually go something like, flash pause flash pause etc until it flashes quickly then it restarts the fault sequence.
if you could let me know how many times then i'll be able to diagnose the fault quicker.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 13, 2008 | Ariston Technologies Ariston AWD12 Front...
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Ariston Margherita 1635
try putting timer dial to the black dot and holding the start button until the red light flashes,then try selecting a new cycle.not sure what country you are in, aristons might be set up different in australia.hope this helps.
Feb 27, 2008 | Ariston Technologies AW149NA Washer
Ariston frontloader - dial spinning around and won't start a cycle
Your bearings are almost certainly gone which would explain the noise not an easy job or cheap . Normally it would consist of a tub change or at best a bearing hub . As for the clicking round of the selector Iwould suggest poss the heater or brush fault. As ofr price you'd have to ask your local repair man. Worst case sinario approx £200 .00
May 30, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Dial clicks round
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily. Good luck !
Jun 15, 2006 | Ariston Technologies AWD121WH
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
