Question about Dewalt 18 Volt Compact Drill Kit
What can i do to make it work up to 50 yards at least
Remote gate opener remote dont work pass 20 yards
    Sergeant:
  • 359 Answers
Install external antenna but need more info to be helpful what type of ant on it now and freq of receiver if possible
Posted on Dec 17, 2008
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
I lost my remote for my Viking R-6 gate opener. the store sold me a liftmaster 890Max remote for it but how do I program it. I can not find the learn button on the viking R-6 gate opener????
The Liftmaster remote you purchased should have come with instructions for programming unless it is preprogrammed to work with your Viking gate opener. You may have to return to the point of purchase for clarification.
Oct 19, 2014 | Building Materials
Why is my mighty mule FM500 gate opener opening by itself?
Cathie,
Thank you for using GTO Products. If the gate opener appears to be opening by itself, then it's receiving an input from an accessory such as a transmitter, keypad, push button, exit wand, photo beam, loop detector, telephone entry system, etc.
By disconnecting these devices and reconnecting them back to the system one at a time, we can use a process of elimination to determine which device is causing the problem.
If you still need assistance, please call our tech support from the gate so we can help you troubleshoot. You can contact us at 800-543-1236 Monday - Friday from 8:00 AM to 6:50 PM EST
Technical Support
GTO Access Systems, LLC
Jun 29, 2014 | GTO Mighty Mule Automatic Gate Opener For...
The air control dash works but no air coming out
Check for leaks under dash check to see all gates are opening & closing , Check the vent gates or the( little doors) that open&close I realy need more info to narrow things down. is fan motor running ,can you hear vent doors opening and closing, can you hear air leaking wene you change settings But its probably The electronic Module under Dash just right of center left side of glove box size Aprox(5-4- 2 maybe a little bigger has 2 looms of wires plug into one side of moduale feels like one but it is two there are locks that hold these in place, ( push tabs) salvage yard 20-40 bucks dime a dozen.
Jun 19, 2014 | 1994 Buick LeSabre
How to program a universal gate remote ?
If you still have the remote that came with the gate controller then you simply match switch positions on both remotes. If that isn't possible then you must open the gate actuator to expose the receiver in it to see what position the switxhes are in then set the universal to match. Be aware that all universal remotes may not have enough code combinations to work. If that's the case then you'll have to get the correct remote for the gate actuator.
Jun 06, 2014 | Multicode Stanley One Button Gate Remote...
Commercial elite gate opener
You will need a remote that works the gate already.... Hold the working remote 3 to 5 inches away from the home link buttons push and hold the remote button and the button on the home link you want to program after a while the home link light will change it flashing patern .... done this will not work with some rolling code type remotes
Nov 02, 2013 | 2004 Volvo XC90
I got my centurion gate motor D3. the problem is when i press the remote an LED lights but the gate does not open, i opened the motor cover and there is no light nor sound from the motor. the gate can be...
Try to reprogram your remotes.... or replace the batteries even if the l.e.d. still works (it only takes half a volt to make the l.e.d. work but almost the full charge of the batteries are needed to send a working signal.
Oct 18, 2013 | Televison & Video
How do i program my lexus 2001 rx300 for a gate opener
You should see three buttons on the driver sun shade. Let's name them from left to right 1,2, and 3. Start by clearing any old codes. To clear codes press buttons 1 and 3 simultaneously until the light starts blinking. Release the buttons simultaneously. Before starting to program the car remotes you must have your gate hand held remote ready with a good charged battery. Now, to program your first gate car remote let's choose button 1. Press button 1 until it start blinking (about 20 seconds). Keeping button 1 pressed, activate your hand held remote close (about an inch) from the car button 1, until the light blinks faster than before. Release both remotes simultaneously. You are done programming your car remote button 1. For two additional gates remote controls programming repeat the procedure with button 2 and then with button 3.
Nov 13, 2010 | 2001 Lexus RX 300
How to use 2 button remote for two mighty mule gate openers
I understanding that the chamberlin is a two button remote so as long as you have the same kind of recierver (a box hooked up in your operator that has dip switches,it recieves signals when the remote and it are set the same.) you should be able to use the two button remote on both machines. If not their is a reciever that is called multi-code and it is universal to work with all gate openers. the chamberlin remote you have will work with it.
Feb 23, 2010 | Chamberlain Clicker Universal Remote...
Dewalt 18 Volt Compact Drill Kit Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
