Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
One of my sensors does not light up
What should i check for
    Champion:
  • 244 Answers
Alignment of sensors and broken wires
Posted on Jan 15, 2009
I have 3 sensor lights that came on at the same time. The brake light,tire pressure light, and the ABS light(I think). A friend had a portable diagnostic computer and plugged it in. No problems...passed....
there area magnitude of things that can be the issue here. I wil take a chance here and say that there is an issue with a couple of sensors. This situation involves 1. The brake light sensor (which indicates that i brake light bulb is faulty) 2. The Tire pressure sensor (which is the tire pressure) and 3. ABS sensor ( Which i would associate it with a wheel speed sensor)
You should check the tire pressure, and correct it. Check the bulbs on your brake light and replace as necessary. Then check for a torn or broken ABS sensor, which are located on each wheel,
May 31, 2011 | 2003 BMW Z4
We have a older craftsman door opener and we now need to hold the button to close the door and the car remote dose not work.
Clear any obstruction from between the safety sensors. Loose leaves, trash, and dirt on the lens of the sensor itself are all examples of things that can obstruct the sensor's signal.
  1. Check each sensor for a steady glowing indicator light. If both indicator lights are on, or if one indicator light is flickering, the sensors may be slightly misaligned. To check for misalignment; obstruct the beam of the sensors so that they cannot see each other. When the beam is blocked, the indicator light on one of the two sensors will temporarily go out. This is the receiving sensor. Remove the obstruction and loosen the wing nut on the back of the receiving sensor. Adjust the receiving sensor until the green indicator light goes out, if not already out, then realign until the green light is bright and steady, then retighten the wing nut. This usually takes a couple of attempts before it is back in alignment.
  2. If an indicator light is out on one or both sensors, check for a possible loose or shorted wire. Sensor wires are attached to the white and black terminals on the back or side panel of the overhead motor unit. Check that they are securely connected to each terminal. Also check the wires for any breaks, especially anywhere they are spliced together.
Jan 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door goes down then comes back up and light flashes
Oct 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opens with remotes but does not close with the remotes
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman will open and close with wall mount switch but will not work with the remote door opener
Garage door will open, but will not close
01 Mazda Millenia 2.5L check engine light
sounds like its a different sensor causing problem. could be TPS SENSOR OR MAP SENSOR .
Dec 06, 2009 | 2001 Mazda Millenia
96 Lincoln town car computer cycle through sensors
the ecm will cycle all of the sensors in the time that it takes you to put it into gear and start moving
on start up you will see all of the required sensors to be checked in the dash lights and when the lights go off , all the sensors are checked
when running any faulty sensors are checked and if the ECM can self adjust to compensate then it will do so
if not it stores a fault code or puts the engine light on
May 24, 2017 | 1996 Lincoln Town Car
I have problem with code 1126 (toyota 4 runner 2001
Manufacturer Specific Codes
P1100
BARO Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1120 Accelerator Pedal Position Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1126 Magnetic Clutch Circuit
P1127 ETCS Actuator Power Source Circuit
P1128 Throttle Control Motor Lock
P1129 Electric Throttle Control System
P1130 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1133 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1135 Air/Fuel Sensor Heater Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1150 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 2)
P1153 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 2) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2)
P1200 Fuel Pump Relay Circuit
P1300 Igniter Circuit Malfunction - No. 1
P1305 Igniter Circuit Malfunction - No. 2
P1335 No Crankshaft Position Sensor Signal - Engine Running
P1349 VVT System
P1400 Sub-Throttle Position Sensor
P1401 Sub-Throttle Position Sensor Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit
P1406 Turbo Pressure Sensor Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1411 EGR Valve Position Sensor Circuit Range/Performance - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1500 Starter Signal Circuit
P1510 Boost Pressure Control Circuit
P1511 Boost Pressure Low
P1512 Boost Pressure High
P1520 Stop Lamp Switch Signal Malfunction
P1565 Cruise Control Main Switch Circuit
P1600 ECM BATT Malfunction
P1605 Knock Control CPU
P1630 Traction Control System
P1633 ECM
P1652 Idle Air Control Valve Control Circuit
P1656 OCV Circuit
P1658 Wastegate Valve Control Circuit
P1661 EGR Circuit
P1662 EGR Bypass Valve Control Circuit
P1700 Vehicle Speed Sensor '2' Circuit Fault
P1705 Direct Clutch Speed Circuit Fault
P1765 Linear Shift Solenoid Circuit Fault
P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
Back To Top Of Toyota Check Engine Light Codes Page
Mar 21, 2009 | 2002 Toyota 4Runner
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
116 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
