Goodmans ghd8015f2 freeview box dead
Switched off tv and freeview box as normal last night
This morning freeview box completely dead, changed fuse in plug but no good
Have nearly full hard drive with recorded programmes.
Can these be recovered or the box fixed?
5 Suggested Answers
  • 51 Answers
SOURCE: Recovery of content on DVR-625 hard drive
usually hard drive failure boils down to files not opening succesfully, or a random internal failure, not a physical issue with the hard drive, however because dish network repairs these issues on a large scale the fix is to wipe the software and start over which means all recordings are lost, unfortunately recovering these recordings is basically impossible... if you often record things which are imperative to your business i would suggest getting a 622/722 dvr which will allow you to download these recordings to an external hard drive via usb, you will have unlimited use uploading and downloading programs for a one time fee of about 40$
Posted on Aug 19, 2008
SOURCE: Thomson DTI 6300 Digital TV Recorder freezes
try this forum http://kafkasworld.com/phpBB2/ they have tons of stuff on thomson dtis
Posted on Dec 21, 2008
SOURCE: Thomson 80gb freeview recorder box (Top up tv model) UK
have you connected the small cable at the back?
Posted on Mar 04, 2009
  • 832 Answers
SOURCE: Disc Error on Goodmans ghd8015f2.(Freeview HD Digital Recorder)
Yes, you can install another 80GB Hard Disk Drive.
The copper plates can be fitted to the new hard drive.
You can format it FAT or NTFS.
Posted on Nov 25, 2009
Testimonial: "fast response. Thank you"
  • 7 Answers
SOURCE: Thomson dti6300-16 won't record freeview channels....
maybe a defragged hard drive follow this procedure:
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Posted on Feb 15, 2010
Will not switch from guide to tv
Did you try power cycling the box?
Aug 28, 2013 | Alba DVBT set top box
Freeview probs
can you try a external antenna on it?
Jun 19, 2008 | Televison & Video
DVB8800HDhas stopped working
Our Celestial set top box has been fine for a year or so but jjust stopped last night. I can turn it on or off but it no longer displays a channel number or menu details. Any ideas, or is it dead?
Feb 13, 2010 | Televison & Video
I cant get my durabrand freeview box to work.
i have pluged in all the plugs to be in and all in the right places but i have no sound but im getting a picture ??????
Nov 22, 2009 | Televison & Video
Can't set up my new Nikkai 5.8GHz video sender.
Could be that the Scart socket doesn't pass through the signals from the receiver. I had a Goodmans TV with Scart input which just didn't respond to the receiver. When I moved it to the Scart connector on my VCR it worked a treat.
Nov 18, 2008 | Televison & Video
Freeview box
After scanning the box should save the channel automatically. If the box does not save the preset after scanning channels, then it is probably faulty.
Some box has a pinhole reset button at the back, if you have this reset button keep it pressed with a pencil for 10 seconds to reset the freeview box.
If it does not work, the nbox is probably faulty.
With freeview you only pay for few scrambled channels, the most of them are free and do not need any additional fee.
Freeview is not available in all areas, check that you have freeview in your location, and that aerial is well connected to the box, otherwise not finding channels is normal.
Sep 05, 2008 | Televison & Video
Sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Jul 19, 2008 | Televison & Video
Philips DTR220/05 digital freeview reciever not recieving anymore
If the box is still receiving some channels, then the box is probably not at fault.
If you have done the full "First time Installation" rather than search for new channels, then eithe the aerial, connection or signal is likely to be to blame.
There have been several changes with the Freeview service over the last few months, and there will be more in the run up to analogue switch off.
In some cases, channels have moved, and in other cases the service has been switched off for a short period, low power etc.
Check the aerial on a standard analogue signal, if the quality is poor, then this rules out the box.
Feb 23, 2008 | Televison & Video
Televison & Video Logo
247 people viewed this question
Top Televison & Video Experts
Electro Med Services...
