Zanussi ZT485 Built-in Dishwasher
Problem for Zanussi ZT485 Built-in Dishwasher
Zanussi built in aquasave zt 685
By markob on Mar 14, 2007
The dishwashed did not drain properly. When you turn off the machine & start again it sounds like it is starting but there is no sound of water entering. After a few minutes when you open the door a few buttons are flashing.
Same Problem
Apr 05, 2008
-   DISHWASHER KEEPS GOING ONTO RINSE & HOLD-   ovem
Jan 07, 2008
-   THE SAME PROBLEMS-   Guest
Best Solution
posted on Aug 03, 2007
Helpful)
dovi
Rank: Guru
Rating: 88%, 2494 votes
Since water doesn't drain out properly ,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again.
Was this helpful?
Yes
No
Solution #2
posted on Mar 09, 2009
Somewhat Helpful)
paulpatrickl
Rank: Apprentice
Rating: 75%, 1 votes
I think I had a similar problem to this. It seems like it was starting a cycle but then it just stalled and made a buzzing noise and it did not drain properly. I opened the bottom of the dishwasher where the draining pump was located. take off the plastic cover and I found bits of broken plates were jamming the fins on the pump... Try this and see how it goes.. Hope it was of some asistance.
Was this helpful?
Yes
No
Popular Solutions for Zanussi ZT485 Built-in
Questions and Unsolved Problems for Zanussi ZT485 Built-in
Do you recommend Zanussi ZT485 Built-in Dishwasher?
Answer
Answer
green light over rinse and hold flashes quickly
Answer
my zanussi dishwasher zsf4123s stopped getting hot,i bought a new heating element but still does not... (More)
Answer
I have a zanussi integrated dishwasher, have used it today, its lit on end of cycle, i have tried to... (More)
Answer
How do you remove the heating Element as I think mine has blown & want to check it..??... (More)
Answer
when turn on the machine, the all lights on but not working.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zanussi ZT485 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
