Ted Pritchard Posted on Jul 26, 2012
Screen does not display numerals in daylight
When I hit any numeral, it's blurry or not the proper number. Weak readings.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jul 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
786
Points
12
Your calculator has been exposed too UV light there is no fix to this problem. Make sure you LED lens stays out of direct sunlight.
2answers
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
My tv model is sony KDL-52VL150 . problem is when i try to turn on after few second it gose standby itsalf's, and also i did unplug from power outlet & put it back & wait, but same thing,...
Hi Mizanur,
First of all, thank you for posting your question here at Fixya.
Your TV has a built in self diagnostic software that can help us diagnose accurately where the fault came from once the unit gone to malfunction. To activate it, press the following buttons on the remote control within a second on each other in standby mode( red LED is on), "Display", "5", "Volume (+)", "Power". Initial screen will be displays as follows :
To display the self diagnostic list, press12_14_2011_11_34_30_pm.jpg on the remote control.
The screen will display the list of error log as follows :
Numerical value "0" means that there's no error detected, "1" means that an error was detected.
Please let me know what error code(s) with numerical value "1" to continue our diagnosis.
Kind Regards,
Jdvillanueva
How to claculate the remainder of a fraction using CASIO fx-991ES?
Use the fraction conversion features of the calculator.
Near (above) the [S<>D] key that toggles display between fraction/radicals and decimals, there is a marking that reads [a b/c <=>d/c]. Accessed through the [SHIFT] key, this key converts from improper fractions [a b/c] to improper fractions [d/c].
Enter your fraction with the fraction key (the one below the CALC key) and press enter. If the numerator is less then the denominator (proper fraction) the remainder is just the numerator. If the numerator is greater than the denominator the display will show an improper fraction (d/c) or a mixed number [a b/c]. Here a is the integer part and b/c is the fraction part.
So, if you have [a b/c] type display the remainder is b.
If the result is displayed as an improper fraction, use [SHIFT][S<>D] to convert the improper fraction (d/c) to a b/c.
2answers
Changin forwarding address from my fax machine
I don't know this exactly machine type.
Please check this extended manual:
http://pdf.superwarehouse.com/specs/Canon_1735B002AA_manual.pdf
Maybe you can get your answer here.
1helpful
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
18helpful
5answers
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
1helpful
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
24helpful
3answers
Change name display on Toshiba DKT2020-SD
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
Keypad number
Try changing your numeric keypad. Use a normal foldable type keyboard instead.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
