Question about HP Compaq Presario V2000 Notebook
Boot issue 1_07
I always get the problem regarding hard drive,that is 1_07
  • sknight46 Jan 02, 2009
    my presario 2000 has become so slow and undependable..processor seems to go off/on...
  • 33 Answers
Recover ur system using F11 during boot.
Posted on Jan 18, 2009
  • Jay Patel
    Jay Patel Jul 21, 2009
    During boot press F10 and go to Dignosies and run hard drive test. If its pass than U have OS problem otherwise It's time to get new hard drive.
We have hp server ml370 when i restart the server its stopped on attempting boot from hard drive c and never continue
This is because either the image on the hard drive is bad (corrupted, missing boot sector, etc) or because the hard drive itself has some issue like corruption etc.
If this is a mirrored raid array (two drive mirroring each other) I would try to remove one of the drives and boot again. If that does not work reinsert and remove the other drive and try to boot.
regards,
Mike
Oct 21, 2012 | HP ProLiant ML370 G4 Server
My toshiba L455 says media failure check cable it will not show normal screen
Hi Terrica,
I saw the Video and see that you Laptop will not boot into windows and regarding the error you just posted, shows that the Windows in the Hard drive is not detected properly and or the Hard driver is not detected properly on the Laptop.
Also this can be a possible boot setting issue, you can go and check in the BIOS Screen see the boot options and make sure that the system is not booting into LAN and 1st boot is CD/DVD, 2nd is the Hard Drive, if these settings are correct then the issue is a Bad Hard Drive.
I hope that this will help regarding your concern.
Have a nice day.
Oct 09, 2012 | Computers & Internet
Acer Aspire T180 - Very Slow Boot to Post Screen
You can run drive diagnostics to test RAM and hard drive, but I would guess that it's a peripheral of some type (I wouldn't think it would be a hard drive or memory problem since your PC runs well in windows). Since the system will eventually time-out trying to initialize a device, it would explain your symptoms. I would unplug your CD drives one at a time (with the system off) and reboot. If you have an onboard card reader, try that next. Printers, headphones, webcams, or any other USB devices can also cause problems.
Once you isolate the offending device, you can try to update your BIOS since some bios updates will address this type of issue. I am not sure if Acer offers BIOS updates, but you could always ask their tech support.
Regardless of the device, it could be an incompatible or failing device. Printers always seem to have updated drivers, so you could check with the manufacturer regarding that.
Otherwise, I would replace the device and test again.
Good Luck!
Dec 28, 2011 | Acer Aspire Computers & Internet
Hp compact mini n110 when you switch on says reboot and select proper boot device or insert boot media in selected boot device and press any key can anybody says whats gone wrong?
Dear User,
Please ensure that the first device under Bios is Hard drive and there shoud be any external device like pen/flash drive is connected and or disc in optical drive. If everything is proper then it seems to be issue with you hard drive.
Regards,
Tech_Comp
Feb 24, 2011 | Computers & Internet
On the screen of my computer is sais " Boot and select proper boot device. Insert boot media in selected boot device and press a key" What do i need to insert to get my computer running?
Dear User,
Kindly enter into setup and change the first boot device to Hard Disk. Also check there should not be any pen drive connected and no disc should be in optical drive.
If still the issue persist then please boot the system with operating system disc and check if detects the hard drive and repair the operating system.
Regards,
Tech_Comp
Feb 22, 2011 | Microsoft Windows XP Media Center Edition...
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
My Inspiron B130 barely works. It has always had issues, making a crackly noise as it boots up. But these days it takes an excruciating amount of time to boot up. I literally have to be reading a book...
i suggest to upgrade the memory of your laptop. make at least 2GB. if the laptop can accommodate such capacity of memory. please also do check in the manual if can accommodate that kind of capacity.
and with regards to a crackling noise. please check your hard drive by using the checkdsk. maybe your hard drive has bad sectors or the disk inside don't function very well.
Apr 07, 2010 | Dell Inspiron B130 Notebook
Disk boot failure insert system disk
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
Jun 25, 2009 | ASUS K8V-MX Motherboard
Hard drive not installed
Try booting from the Operating system disc, into the recovery console.
check when booted, where your hard drive is.
if not try safe mode, reboot tapping F8 while booting,
choose safe mode from list, check for hard drive when booted in places like,
My computer, device manager, anywhere on the desktop if you get there,
If your savvy, ESD kit, check connections to hard drive, swap out cables if poss.
it's on IDE so no SCSI driver issues..
But if powered up, and cannot be located on desktop after multiple checks,
That's a possible hard drive failure.
Regards.
Apr 11, 2009 | IBM ThinkPad T20 Notebook
Restore hard drive and wipe out everything on it
Dell always send with a new computer one cd to restore the OS of the computer.
If you have this CD put it into the CD drive and boot the computer, follow the instructions on the screen.
Or put an windows CD into drive and boot the computer.If you use this second option you will have to download the device drivers from dell support page.
Best regards
Dec 19, 2007 | Dell Dimension 3000® Pentium® 4...
HP Compaq Presario V2000 Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
