ASUS A6QOOVA laptop freezing
I have an asus A6QOOVA laptop for some years now. I did a format , reinstalled windows XP, but still freezes. When I use the wifi,although it is connected to the internet I get the sign that internet explorer cannot find page , not connected to the internet(when at the same time my mac works with the same internet connection). I Had windows repairing the connection it works for some seconds and again cuts off.Is there a way to repair the laptop or I need to get a new one, as also it freezes when opening some applications as well.
sandrew
  • 2961 Answers
SOURCE: exactly ASUS WL-500g, no internet connection
My advice and personal experiences with both wired and wireless connectivity, is if you wish to share files and internet connection, purchase a combined Modem/Router and not a seperate router to work along side your original modem. Your modem will send your router an ip address in turn your pc is sent one from your router and can get complicated; keep it simple! These are much easier to set up and control as one unit and if there are ever any connection problems you will know it's either a setting or a modem/router problem and not have to wonder ; is it the modem?; Router? settings? etc. As there are frequent loss of connections both internet and LAN it makes sense have one peice of equipment to maintain.
Posted on Dec 22, 2006
  • 556 Answers
SOURCE: i have to repair my connection to get internet
Are you running a virus scanner or internet security software?
Is it active and has it been updated recently?
Do you perform periodic full scan of your systems and are they clean?
Do you run any apyware packages?
Are they active and have they been updated lately?
Do you perform periodic scans with them and is your system clean?
Not all virus scanners, etc catch all problems. Some catch different items.
Consider using free online services from some of the security vendors to double check your product. Several to consider
Trend Micro
Fsecure (www.fsecure.com and search for online scanner)
Symantec
Consider free spyware software for additional checks if you have not choosen to purchase a product to do this.
Lavasoft
Spybot
Clean up the issues found and see if the problems are eliminated.
Using the following instructions from the zonet website to get your IP address will also reveal your router's address in the default gateway entry (assuming your computer receives it's IP information via DHCP from the router or has been staticslly configured correctly). This will be the value you utilize instead of 192.168.1.1 to access the router's configuration.
spacer.gif Q: How can I find the IP address of my computer? spacer.gif A: Windows 95, 98, and ME:
Click on Start.
Then click on Run.
The Run Dialogue Box will appear. Type "winipcfg" in the window as shown then click OK.
The IP Configuration window will appear, displaying your Ethernet Adapter Information.
Select your adapter from the drop down menu.
If you do not see your adapter in the drop down menu, your adapter is not properly installed.
After selecting your adapter, it will display your IP address, subnet mask, and default gateway.
Click OK to close the IP Configuration window.
Windows 2000 and XP:
Click on Start and select Run.
Type cmd then click OK.
From the Command Prompt, enter ipconfig. It will return your IP address, subnet mask, and default gateway.
Type exit to close the command prompt.
Macintosh 8.x and 9.x:
Click on the Apple Menu>Control Panels>TCP/IP.
Select your Ethernet adapter from the Connect Via drop-down menu.
Under Setup, select Using DHCP Server from the Configure drop-down menu, if connecting to a router DHCP server. This is the most common setting when using a router. In this configuration, your computer will be automatically assigned an IP address by the router.
You must reboot your computer to "renew" your IP address.
Macintosh OS X:
Click on Apple Menu>System Preferences>Network>TCP/IP.
Linux:
At the command line type /sbin/ifconfig and you will get a listing of information. Your IP is shown after inet addr.
Posted on Dec 08, 2007
SOURCE: wifi is not working
try to update rom image or radio image to newest version if nothing is change down to your device rom image file
Posted on May 12, 2008
Kurth
  • 86 Answers
SOURCE: WIFI SD CARD
Test the network capability - ping your card and also do an auto detect through home network set up.
If it still doesnt feature, unplug, reboot phone and replug. shoul;d work!
Posted on Aug 16, 2008
SOURCE: AUDIOVOX XV6700 won't connect to wifi
Tap the "EV" or "1X" icon on the top of the today screen, and then tap settings. Select the Wireless LAN, and then tap the icon in the bottom left corner that looks like a target with parenthesis. That just got you to the communication manager. There you can toggle your "phone" on and off, as well as bluetooth, wireless and sound, among others (depending on what you have installed). when you tap the antenna for wireless, does it turn green, and the little "x" go away? That's what you need to figure out first, after that we can go look at some other things....
Posted on Aug 18, 2008
Asus r1f stylus pen didn't work
reinstall drivers from asus support website
Nov 11, 2012 | ASUS INTEL CORE 2 DUO T7200 2.0GHZ...
After windows XP loads the mouse pointer freezes. It is not frozen, however, when the netbook is booting. it is an eee pc asus. thanks for any help
Start the laptop up in safe mode, remove the mouse driver and re boot the laptop. Windows will see there is no driver and load a fresh one. Assuming the driver that you have is the correct one, Asus use their own, it will work.
Dec 24, 2010 | ASUS Eee PC 1000HE Netbook
LAN driver Freezes Computer
disable the motherboards built-in ethernet adapter in BIOS and get an add-on ethernet card. it sounds like your ethernet card is damaged and its affecting the rest of the computer.
May 22, 2010 | ASUS P5B-E Motherboard
My asus eee pc series keeps freezing and nothing
most likely you have contracted a virus and need to reinstall windows. the only other possibility is a major hardware issue
Dec 28, 2009 | ASUS B50A-A1 P8400 Notebook
Bios version for asus eee pc 10005ha touchpad screen freezes
Its not the Bos,just dont corrupt the boot procedure with unnecessary key presses.
Or reinstall factory settings properly--it has very little to do with the bios
Dec 18, 2009 | ASUS Eee PC 1000H Laptop
Hello there, I have laptop Asus, Z100L. Very occasionally the screen will freeze and turn black. Can you suggest any checks?
you should format and reload your system with the original version of Microsoft windows xp service pack 2
Jan 13, 2009 | Computers & Internet
I am trying to install a gigabyte gn wpeag wireless network pci network adapter onto a p5q asus motherboard. when i try installing the dirvers, the keyboard and mouse freeze. i am running xp 32 bit. i have...
Format your Hard DIsk in which you've installed your XP and reinstall the XP. If this doesn't help, take your Machine to the Hardware Engineer/Mechanic.
Aug 05, 2008 | Computers & Internet
Computers & Internet Logo
340 people viewed this question
David Payne
David Payne
