Question about HP Officejet 4315v All-In-One InkJet Printer
Printer does not print
The paper feeds through as though it is printing but returns to the lower feed tray blank.
  • ne12056spghl Dec 14, 2008
    This is a HP Officejet 4315v All-in-One
  • 112 Answers
i think your ink level is low
R
your cartridge is not plug in properly
Posted on Dec 14, 2008
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
The printer does not print. It feeds paper and
Visit HP support for this problem (XP):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01853840&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443024
If you have Vista, change query to read "Printer prints blank sheets of paper" > Choose Vista instead of XP
Dec 05, 2009 | HP Photosmart 8250 InkJet Printer
I have an hp 4200n that picks up an extra blank page when i print a menu map. the paper (blank page only gets up to the delivery assy past the fuser, no jam error). this happens when i print it from tray...
Hello, you must clean separation roller whit wet cloth or alcohol. Remove Tray 2, look for blue (usualy) cylinder feed rubber on it and clean Good luck. P.S You can clear paper feed roolers too (look at printer bottom after removing Tray 2) using same way!
Oct 15, 2009 | HP LaserJet 4200n Printer
The mechanism that takes paper from the tray to the printing area feeds several pages at once so i get printed page, blank page, blank page, printed page, blank page, blank page etc
I am not sure of the printer that you have, but it could be that the seperator pad is dirty or the paper feed rollers are dirty. You can clean them with a little isopropyl alcohol and a soft cloth, Make sure the printer is off when doing this procedure.
Aug 19, 2009 | Office Equipment & Supplies
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 4315v All-In-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
