Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Only red on Sony Rear Projection 53" TV DRC-MF/MID-X
The green and blue bulbs works when I unplug the base of the CRT from the red , and the red over power when all connected and the TV seitch off after a few second
Loss connection? Something to replace?
Thanks
JP
Why my 53 sony drc mf coming sound but on after ten green light blink otometic s of wich
10 blinks won't occur, as per its repair manual. It might be 9.
Audio error If you wish to get some details; check the site linked here. Pull up older posts.
Jul 16, 2016 | Sony KP-53HS30 53" Rear Projection...
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Sep 22, 2009 | Zenith R57W46 57" Rear Projection...
Looking for lights....
You can find replacement parts for this model from the following Sony OEM parts distributor. Here's the links to order the original Sony blue CRT, green CRT, and red CRT (the 3 "light bulbs") for this model from that major parts distributor if needed:
Sony KPR-53CX35 Replacement Part Blue CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Green CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Red CRT Bulb / Lamp
Apr 01, 2009 | Televison & Video
Hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
Dec 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture changes focus/sharpness instantly and then recorrects
Hi
You can try and get more infornation for me.
Go into the the menu by pressing the WEGA GATE button on the remote. In the sub menu of picture adjustment switch the DRC-MF setting to off. It should read normal.
See if this stoppes your focus problem.
If it changes let me know for further directions.
Feb 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Green bulb for projection tv
I found the lamps at PartStore.com for $146 plus ship/hand/taxes
Feb 02, 2008 | Sony KP-53HS10 TV
PT-53wx53 replacement bulb
Your model doesnt have a bulb. The PT 53WX53 is a progressive scan CRT projection TV. You have 3 CRT Tubes, Red, Green And Blue. Hope this helps. If you need more info let me know.
Jan 30, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Sony Wega 34 inch Tru Surround DRC MF
check q8014 and q8013,r8051 and ic8005 on d board
location is seen under the green printed circuit board
Sep 30, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
554 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
