Question about Alpine CDA-9830 CD Player
Alpine 9830 subwoofer adjust not working
I have the preout connected running to the amp for the sub but i cant adjust up or down on the alpine?
  • 24 Answers
Turn on the subwoofer cross over which turns on the out put
Posted on Feb 17, 2009
I have a Kenwood kdc-mp342u car cd player installed in my truck. I have subs hooked up to it and everything was working fine until i had to reset my radio and when i reset it the "sub Level...
Subwoofer output: Hold the (AM-) button down for at least two seconds. You can do this function when "SWPRE" in is set to . The SWPRE (Switching Preout) Switches the preout between rear output ("R") and subwoofer output ("SW").
Nov 10, 2010 | Kenwood KDC-MP342U Car CD Player
Continous low level pulsing but no Base Response from JBL PSW1000
There is a huge discussion among audio enthusiast regarding subwoofer output and how you should connect your sub to your system. If sub preout is turned and on your amp/receiver and you are able to adjust the crossover frequency adjust your crossover frequency to highest setting, higher HZ number, so you don't double low pass filter your signal too much. If you can adjust crossover frequency on your receiver and your sub allows separate connection to by pass it's filter, use that instead.
There is a great article on Polk Audio website regarding Home Theater setup. You can use it as reference and tweak it to your taste.
Aug 18, 2009 | JBL PSW1000 Speaker
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
May 16, 2009 | Kenwood Audio Players & Recorders
Alpine x200 Subwoofer Preout pushing out a weak signal
Hi, just turn up the gain, though the max voltage may be higher, it does not mean the audible output is higher, alpine decks subwoofer control is an attenuator, so at max it will be the same level as front n rear, on min it is -15db... you will probably find the kenwood is +/- 7db so it has a gain boost...
just crank up the amp gains, problem sorted...
Dec 11, 2008 | Alpine iDA-X200 Car CD/ MP3 Player
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Sub output
With RCA cables. Just plug into the preamp outputs on the back that are labeled for "subwoofer" and run them to your amp. In your on-screen EQ, you'll have a separate adjustment for the sub (which adjusts that set of preouts, without affecting the tone in the rest of the speakers).
Jul 14, 2008 | Jensen's VM9312 Car DVD Player
Need to know the right setting to apply for my subs
You need to match your amp's input voltage (the gain) to the output voltage supplied via your deck's preouts. Turn you radio up to normal listening level, and turn the amp's gain until you induce audible distortion then back it off slightly. Set the bass boost and crossovers to on and type (highpass for front/rear full range or lowpass for subs).
Apr 26, 2008 | Jl Audio 12W3 Car Subwoofer
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Rampage BA-100 200W amplified subwoofer
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
Jan 22, 2008 | Audiovox BA100 Car Subwoofer
Alpine CDA-9830 CD Player Logo
125 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
