LG LE Error code
My LG washer started making noises like it's trying to spray water and rotate the drum and nothing happens then I get the LE error. I unplugged it and it's still not working, anthing else?
    President:
  • 373 Answers
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
for more info check out this link:-
http://appliancejunk.com/forums/index.php?topic=1735.0
Posted on Dec 14, 2008
LG washer IF82 code. What does it mean? This is a washer not a dryer.
LE error is hall sensor is bad or bearing not letting motor turn
Aug 05, 2014 | LG WFT1071TP Top Load Washer
LE error drum won't spin.. replaced hall sensor and harnesses
look under the unit and see if the transmission solenoids are working..a wire may have dropped off..
Jan 12, 2014 | LG WM-2277HW Front Load Washer
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
Drum starts to move then stops then Le appears and a slight hissing noise from direct drive motor. Looks like intemittant fault
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
Aug 11, 2011 | LG WD-1080FD Front Load Washer
Hi, My machine is not spinning and I keep getting an LE error. It makes a weird noise. What can I do to fix problem?
Jan 13, 2011 | LG Washing Machines
ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
May 28, 2010 | Washing Machines
Lg wd8074fhb will not rotate drum on was or rinse
LE=Load Error CE=Cycle Error
Unplug at socket for two hours will reset the Error Sensors. The sensors are there to prevent overheating of the motor and the possible risk of a fire.
Load Error is linked with too much weight in the drum. Cycle Error is limked with an uneven load.
If it happens again, unplug for two hours to reset the Error Sensors.
Hope this helps.
Nov 16, 2009 | LG Washing Machines
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
Oct 28, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
192 people viewed this question
Top Washing Machines Experts
