Question about Samsung Color Fixed Security Camera Sod-14c
I bought a CCTV system for a school but I have some electric problem that the image looks like it's flashing? what is the problem since Iam new to this. IT's like it has brightness
  • Jasem79 May 11, 2010
    I mean the picture is really really bad
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 14 Answers
Line loss from the camera to the DVR or monitor and ground loops are the most common problems. If you only see black and white from a color camera, it typically means the cable from the camera to the DVR is too long and/or has high loss caused by a poor BNC connector.
Excessive brightness can mean the video signal from the camera is too strong. This can be caused by an impedance mismatch from using the wrong type of video coax (cabling).
Additionally, a camera power supply plugged into a different electrical circuit (not the same outlet as the DVR or montior) can cause ground loop problems that can affect the video quality.
Posted on Dec 28, 2008
Hi,show in enternet exploar when connect ip camera samsung snc-b231((
Sorry, file not found
Posted on Dec 21, 2012
Nightwatcher nw ac720d cctv camera just bought new not working but red lights on
Red lights on means : Camera getting power.
No Video Means: your connection or BNC Connector is bad or not connected properly.
CCTV Networking Technical Support
Nov 26, 2017 | New Home Security
I have a Swann CCTV DVR4-0044 720p 2x Cameras both we're clear night and day when new. Both now have very grainy poor pictures at night. I bought a new power pack following instruction, it didn't work
the cctv chip gets old and grainy. i have had to replace the camersa on some of my locations at least ones since new. plus if you haven't yet cleaned the glass over the lens do so. i have to clean mine at least once a year. yea tough job but then again you want security cameras and they do need maintenance. good luck with them.
Oct 17, 2017 | SWANN Home Security
I have a wireless surveillance system, 4 chanel. came with 2 cameras. have purchased additional camera. How do I get the system to accept camera?
I am going to write a short discussion because I feel this subject is best handled by a person that knows what they are doing. There are plenty of Youtube videos that shows you how to install a CCTV system. As you didn't mention what type of CCTV camera it is, can this topic become very lengthy.
Please look at this tutorial on youtube,
The old systems is not difficult to do it yourself if your technical minded, although the newer systems will require some IT background. I recommend a certified installer to assist you, you can damage the camera if you don't know what your are doing.
Get the correct cabling and connectors.
The easiest are the pre-crimped cabling for DIY and it is plug and play. No setup is usually required for the CCTV recorder to work unless the recording on the CCTV was disabled. Any other setup will require special tools.
You get 2 kinds to wired CCTV camera systems.
The old tech is analogue with a thick data cable and set of wire for power.
The professional installed cabling will require a technical person to crimp the CCTV cable with a special BNC crimping tool. The
The old systems needs to have
The newer systems uses LAN cables.
The newer systems requires an IT/CCTV tech person to set it up.
Sep 19, 2017 | Came Home Security
Outdoor Digital Wireless 2 CCTV camera System 7" LCD monitor DVR Record to SD TF but recorded playback poor what can I do please I am 81
Try recording in a higher quality than standard and see 2hatcthe results are.some of those are low resolution cameras and you won't get a wonderful image out of them.
Jun 28, 2015 | OUTDOOR Home Security
I have a Sentient CCTV System and now all the screens on the monitor have lines going across them as if there is some sort of interference, do you know how to stop this ?
Look for Totally tight cable connections. A break in the grounding causes the interference, usually. It only takes a slight loose connection to have issues.
Jun 28, 2011 | Home Security
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
I am using this monitor with our CCTV system, it is not currently displaying the video. As I cycle through the inputs the video image will display for about 3 seconds before disappearing.
Hello there,
ok so if i understand this problem correctly you have a Monitor connected to a DVR for a CCTV System, when cycling through the inputs on the Monitor you find the correct input for the CCTV system but the monitor only stays on this input for a few seconds .
sounds like the input is going out or the Monitor is programed to stay on a single Input, I would try both move the CCTV System to another Input on the Monitor and if that fails see if the Monitor has any Pr-Set settings then you can Default .
if you need any Help with the Default let me know and i hope this information was helpful don't forget to Rate.
Jan 27, 2011 | Bosch MON152CL (Black) 15 inch LCD Monitor
My sentinel cctv when powered on all the indicator lights flash on and off and there is a clicking sound. Any idea what the problem is?
hello sunrisepmp, i bought the model lorex l19wd and i have some problems with the remote connection. i can`t view my cameras remotely...
Locally everything work perfect but when i try to establish a remote connection, the lorex client 7.0 tell me that the connection is sucessfully but i can`t see any image.
I`ve a linksys wrt54G router and a speedstreem 4200 modem, i connect the system directly to the modem, also i create an DDNS Account (i had a doubt about the mac adress that you have to put at the form, i filled with the mac of the system) and i configured the system with the information that you sent me to my email, like the manual said...
Thank You
Mar 11, 2009 | Home Security
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Problem
i need help joining online
Feb 03, 2008 | Microsoft Xbox 360 Console
Samsung Color Fixed Security Camera Sod-14c Logo
602 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
