Question about HP Photosmart 120 Digital Camera
Been using rechargable batteries with no problem. Battery showed low after charging so I bought new ones- charged them and put them in- still low- re- charged and tried again. Was using NIMH AA rechargables. The camera goes on & I can move around but the shutter button will not take a picture. Memory requires formatting comes up on the screen and I do not know what this is. Would appreciate any help, Thank you, Mary
  • HP Master
  • 5,534 Answers
You will need to use 2100 mAh or 2500 mAh rechargeable batteries, as others are not powerful enough. To format the card, look in the menu system (or, indeed, in the manual) for the 'format' command.
Posted on Jul 09, 2017
SOURCE: HP photosmart R707 camera does not turn on and charge
I Recomend you to charge your camera before it reaches the lowest level of charge displayed in the LCD Screen This might help the camera to turn on again after long usage but this is something you must take in consideration before it gets ruin but if it is already ruined and you have good luck you might be able to turn it on again and then you shall follow my advise.
Posted on Jan 04, 2008
Maanita
  • 1142 Answers
SOURCE: I have a HP Photosmart
You have to go for a rechargeable battery as duracell doesnt have enough current as the camera consumes more energy then a rechargeable battery has. go for uniross 2200 mha battery that is pretty cheap and best.
Posted on May 22, 2008
SOURCE: Batteries
You can try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries and you will see a difference.
Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
Posted on May 24, 2008
  • 148 Answers
SOURCE: Even with new batteries and they go dead before I take 3 pictures
Yes, there is definitely a fault with your camera.  You should be able to return it for a replacement.  I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
Posted on Dec 11, 2008
  • 43 Answers
SOURCE: HP Digital Camera R717 Charging Flash Error
Try to run self-diagnostics test - press flash button while switching the camera on. One of them tests the flash functionality.
Posted on Jan 28, 2010
Hp photosmart M23: can I charge new batteries in the camera
The batteries can be recharged in the camera with the appropriate adapter or dock. See page 155 of the manual.
Oct 17, 2012 | Cameras
CAMERA M425 HP PHOTOSMART
use AA duracell batteries with high amps.
that would help you
Sep 16, 2008 | HP Photosmart M425 Digital Camera
I bought a HP CA 350 digital camera of 10 Mpx I use Ni-Mh batteries of 2500 mAh (adjusted on the camera) and although the batteries are not exhausted it happens the camera to switch off previously...
Try new batteries which are not rechargeable and see if the camera works correctly. Ni-Mh batteries can cause problems. Firstly, a standard non-rechargeable battery will be 1.5V but rechargeable batteries are only 1.2V. So if your camera takes two batteries, it requires 3V, but is only getting 2.4V. The battery monitoring circuit in the camera will be looking at the voltage of the batteries to determine if the voltage is dropping to the point where the cammera cannot function. As the camera draws more current from the batteries during certain functions e.g. zoomingor charging the flash, the battery voltage can dip with rechargeable batteries and this may cause the camera to think that the batteries are running out of charge.
Jul 03, 2011 | HP CA350 Digital Camera
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
I have a HP Photosmart M415 digital camera 3 years old. It will not hold the charge in the rechargable batteries and also when I replace them with Duracel I can only take about 10 photos and then the...
May 22, 2008 | HP Cameras
Flash won't fire
charging flash:-
POSSIBLE CAUSE:The camera is recharging the flash.
SOLUTION:It takes longer to charge the flash when the battery is low. If this message appears a lot, replace or recharge the battery.
Dec 28, 2007 | HP Photosmart R607 Digital Camera
CAMERA IS NOT FLASHING
The camera is recharging the flash. (possible cause)
Solution: It takes longer to charge the flash when the battery is low. If you see this message alot, you may need to replace or recharge the battery. Hope this helps!
Nov 27, 2007 | HP Photosmart M407 Digital Camera
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
I just bought new rechargeable batteries, and got only a few shots. Why so little usage from new batteries? Is something wrong?
Nothing is wrong with the camera or the batteries. Rechargeable batteries of all kinds will self-discharge over time. Charge them fully (if they are NiMH completely charge and discharge them a few times), and you should see full battery capacity.
HP Photosmart 120 Digital Camera Logo
51 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
teddyboy
Are you a HP Camera Expert? Answer questions, earn points and help others
