Question about Dell F3534 Touchpad
Inspiron 1525 battery doesn't completely charge and a/c adapter not reconized. My laptop is only two months old so I called dell and they said I needed another battery and motherboard. I can't do wothout my computer for 8 weeks. It doesn't seem real that I would need these items so quick after purchasing the computer. Can you help me?
  • 155 Answers
It shouldn't take more than 2 weeks to have them replace the motherboard or the battery unless you're asking for a system replacement. The only way you can fix that is by replacing the parts.
Posted on Jan 02, 2009
My laptop is dell inspiron 1525 but battery is not charging i have replaced the battery and even i have used new adapter but i cant solve the problem please help me to fix it
please remove the battery, plug-in the charger and turn ON the laptop, if it doesn't work,
then the internal part that connects the laptop to the charger have problem and need to be fixed through a technician.
Good Luck
May 13, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
if that fails to resolve next is the motherboard
Mar 14, 2010 | Dell Inspiron 1525 Notebook
I have a Dell 1525 Inspiron that is 18 months old. It will not do anything. When battery charger is plugged lights are even coming on. It has been doing this for 3 days but once in a while after...
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 24, 2009 | Dell Inspiron 1525 Laptop
My Dell Inspiron 1525 will not power up at all. The adapter works, however the battery is dead. The battery stopped charging about 6mos. after I purchased the unit. I did notice that where you plug the...
i had the same problem... there can be a few reasons why... the adapter i had was at first able to charge the battery... for some reason it stopped charging the battery but was still able to keep the power on... i had a friend who also had a dell laptop and for some reason his adapter was able to charge my battery so it wasnt the battery... i called dell and they sent me another adapter and that was able to charge it...
Jun 16, 2009 | Dell Inspiron 1525 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Inspiron 1525 battery doesn't completely charge and a/c adapter not reconized. My laptop is only two months old so I called dell and they said I needed another battery and motherboard. I can't do wothout...
Update your power supply driver. There are some problem about dells power supply system. It also cant recognize the battery. If this cant solve the problem, advise you buy a new laptop battery replacement . Dont buy dell expensive OEM battery, see something in revive dead laptop battery in or you can cheap replacement there.
Good luck.
Dec 14, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
47 people viewed this question
Alun Cox
