Question about HP Computers & Internet
The lcd display of my laptop hp dv6915nr remains dim or barele redeable
  • elokafe Dec 18, 2008
    I have tried all these solution without any satisfaction,my laptop is very new, only two weeks old and it was the third time I switched it on, in fact I have opened a game program(luxor3) from my USB key plugged in my laptop, but when it opened I have played the Luxor3 for about 03 minutes, and suddently while playing I have just saw the display going dim and barely readable till now. I have tried the above solutions you gave but no change so far.
    Scholar:
  • 120 Answers
Maybe the display brightness is low. Go to Control Panel and check somewhere. Also, look for a brightness key. My F7 and F8 have brightness up/down in rectangles.
Press the 'Fn' (Function) key and press the brightness up key. You're up and ready. Go, enjoy!
Posted on Dec 14, 2008
Removing back cover of hp dv 6915nr
Back Cover?
1) Display Cover: The plastic cover that is on the opposite side of the LCD screen. Sometimes referred to as Top Cover.
Display Assembly is removed from laptop first, then LCD screen assembly is removed from the Display Cover.
2) Base Enclosure: The plastic bottom part of the notebook.
A laptop is disassembled from the Top down to the Bottom.
The bottom 'cover' (Base Enclosure) is not removed first. It is last.
3) There is no back cover per se. Half of the cover for the back (Bottom half) is part of the Base Enclosure. The top half is part of the Palm Rest.
(The back has the Vent in it)
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
[Use the dv6700 service manual. Go down to the subheading HP Pavilion dm1 (dm1 is in blue)
Scroll to the right, click on dv6700. Note that it is a PDF file, and may take up to 30 seconds, before you see the first page come up ]
What is it you are trying to do? What hardware component are you trying to access?
Post back in a Comment.
Regards,
joecoolvette
Display assembly is removed. Palm Rest Cover is removed, and so on.
Jan 14, 2012 | HP Pavilion dv6915nr Notebook
I shut my computer down, I then traveled about 10 minutes in a car. When I arrived the computer had not been dropped and nothing hit it. When I attempted to turn it on it booted all the way. I could hear...
It is for sure that a damage is done on the LCD and it needs to be checked on HOW THIS HAD HAPPENED.
It seems that if the laptop was not shut but the LCD display door was made to stay OPEN while you were driving then the motion/vibration could have damaged the LCD or the linking wires to the LCD panel. Check carefully on the hinges of the laptop and see if there is any cracks. Also if there is display on an external monitor then the PC is working fine . You can open the laptop and ccheck if any connector of the LCD panel is loose. If no the LCD is a suspect and You must take an opinion from HP. Claim for warranty if the time limit is within.
Jul 13, 2011 | HP Pavilion dv4-1140go Laptop
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
No light from my replaced display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 28, 2009 | HP Pavilion dv5000t Notebook
HP Pavilion dv1000 Notebook PC display not coming on
Does the laptop power up even though you can't see an image on the screen?
Connect an external monitor to your laptop and powe it up, if you see the normal Windows images then the laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 22, 2009 | HP Pavilion dv6000t Notebook
I need sound driver for my hp dv6915nr
All the drivers including the sound driver for your HP DV6915NR are available on this page
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3740559&lc=en&cc=us&dlc=en&submit.y=6&submit.x=6&lang=en&cc=us#
First you are asked to select the windows you are using and then the download will be preseted to you.
Anything else?
Nov 19, 2008 | Computers & Internet
DV4000 lcd goes dim
Have you checked your power options in the control panel to see what they are set at? Has this always been a prob, or is it something that has just started?
Oct 26, 2008 | HP Pavilion dv4000 Notebook
Backlight only stays on for a few seconds on compaq c700 that is only a year old
When the external AC power supply is unplugged from a notebook, the LCD display will dim to conserve on battery power. During times of heavy battery power operation; such as during the startup or boot process, the display may be very dim or barely readable. If the display remains dim when the notebook is operating on the Windows desktop, follow the steps below to resolve problems with display brightness Restart the notebook with AC power Follow the steps below to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the power button for 5 seconds.
  3. Press the power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected, try changing the LCD brightness. Adjust the LCD brightness using the function keys From the Windows desktop, hold the fn key and press the f7 key c00776226.jpg to increase or the f8 key c00776225.jpg to decrease the brightness of the display. If using the function keys does not resolve the problem and you have a Lid Actuator on your particular model, check the movement of the Lid Actuator switch to determine that it moves freely and is not stuck. NOTE: The key numbers ( f7 or f8 ) may vary depending on the notebook PC; however, the images on the keys should be familiar. Check the movement of the Lid Actuator switch The Lid Actuator switch is available on some models. It is a small button or switch located above the keyboard near the hinge for the LCD. Pressing this switch when the computer is on may turn the notebook display off, or it may cause the notebook to enter a different power state. Press the switch two to three times while observing the display. If the display does not return to normal brightness when the switch is released, the switch may be sticking and need to be repaired. Contact HP service and support for further assistance. If the display turns off when the switch is pressed, the power management function may be set to hibernate or turn off when the lid is closed. Install updated BIOS and drivers To resolve certain hardware and software issues, use HP Health Check to automatically search the HP web site for an updated BIOS as well as any updated software and drivers. To launch HP Health Check, follow the steps below.
  1. Click Start , type health into the search field, and then select HP Health Check from the list. HP Health Check displays a list of available BIOS, software, and driver updates for your particular model.
  2. Click the description link for any BIOS, software, or driver updates, and then follow the on-screen instructions. You can only install one update at a time.
  3. Repeat steps 1 and 2 above for all updates that you want to install.
You have now installed the available BIOS, software, and driver updates for your particular computer model. Contact HP service and support If the display remains dim after doing the troubleshooting steps listed in this document, contact HP service and support for further assistance.
Oct 15, 2008 | Computers & Internet
HP dv1000 monitor just stopped working.
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Jun 05, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
