Question about Dell F3534 Touchpad
Inspiron 1525 battery doesn't completely charge and a/c adapter not reconized. My laptop is only two months old so I called dell and they said I needed another battery and motherboard. I can't do wothout my computer for 8 weeks. It doesn't seem real that I would need these items so quick after purchasing the computer. Can you help me?
  • 1 more comment
  • Anonymous Jan 02, 2009
    well i have inspiron 1525 bought in july 2008 battery won`t charge and a/c adapter is not being detected it says plugged in not charging
  • rohanid Jan 02, 2009
    well i have a dell inspiron 1525 a/c problem is not being detected and battery won`t charge it says plugged in not charging
  • dvoak Apr 15, 2009
    AS PER DIRECTIONS FROM DELL I INSTALLED 1525_A16.EXE
    BUT MESAAGE COMES - AS NO BATTERY DETECTED
    dvoak@indiatimes.com
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
Update your power supply driver. There are some problem about dells power supply system. It also cant recognize the battery. If this cant solve the problem, advise you buy a new laptop battery replacement . Dont buy dell expensive OEM battery, see something in revive dead laptop battery in http://www.laptops-battery.co.uk/blog/revive-dead-laptop-battery.htm or you can cheap replacement there.
Good luck.
Posted on Dec 27, 2008
Battery charging problem
Posted on Jan 04, 2010
2 Suggested Answers
rachelgeek23
  • 155 Answers
SOURCE: Inspiron 1525
It shouldn't take more than 2 weeks to have them replace the motherboard or the battery unless you're asking for a system replacement. The only way you can fix that is by replacing the parts.
Posted on Jan 02, 2009
My laptop is dell inspiron 1525 but battery is not charging i have replaced the battery and even i have used new adapter but i cant solve the problem please help me to fix it
Hi
please remove the battery, plug-in the charger and turn ON the laptop, if it doesn't work,
then the internal part that connects the laptop to the charger have problem and need to be fixed through a technician.
Good Luck
May 13, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
I have a Dell 1525 Inspiron that is 18 months old. It will not do anything. When battery charger is plugged in...no lights are even coming on. It has been doing this for 3 days but once in a while after...
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 24, 2009 | Dell Inspiron 1525 Laptop
My Dell Inspiron 1525 will not power up at all. The adapter works, however the battery is dead. The battery stopped charging about 6mos. after I purchased the unit. I did notice that where you plug the...
i had the same problem... there can be a few reasons why... the adapter i had was at first able to charge the battery... for some reason it stopped charging the battery but was still able to keep the power on... i had a friend who also had a dell laptop and for some reason his adapter was able to charge my battery so it wasnt the battery... i called dell and they sent me another adapter and that was able to charge it...
Jun 16, 2009 | Dell Inspiron 1525 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Inspiron 1525 battery doesn't completely charge and a/c adapter not reconized. My laptop is only two months old so I called dell and they said I needed another battery and motherboard. I can't do wothout...
Dec 14, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
2,308 people viewed this question
Alun Cox
