A55-S1063 Satellite
SOURCE: Toshiba satellite a55 s1063, driver wireless
They are all right here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1132282&rpn=PSA50U&modelFilter=&selCategory=3&selFamily=1073768663&selModel=1132282|PSA50U
Click on the Downloads tab and then choose windows xp as your operating system and you can download any of the drivers that you need from that point.
SOURCE: No Power Toshiba A55-S1063
sounds like the powersupply might be bad try another one if that dont help then your board is bad -sorry
SOURCE: put two gegs of ram in my toshiba satellite a55-s1063
1. The ram you put into your computer man not be compatible with the computer itself. You can find out what kind of memory your computer takes by doing a google search or asking a technician at your local computer store.
2. You may have put too much ram in. www.pcmemorystore.com sells as its largest ram chip for your computer a 512meg stick. This likely means that the most memory your laptop can take is 2x512meg, or 1 gig.
3. The memory may not be correctly seated. Installing memory isn't rocket science, but you have to make sure you have the chips seated properly before trying to boot your machine.
SOURCE: latest graphics driver for Toshiba a55 s1063
run the update utility,be sure to allow active x control to run when drop down box appears say run,otherwise it wont work follow this link to get started
http://www.intel.com/support/graphics/detect.htm
hope this helps,aloha from maui todd0708
SOURCE: my sound card is not working on Toshiba a55 s1063
First thing check drivers
START>Computer (right click) select manage>computer management open left click device manager
check no conflict or that drivers are installed
Link for audio driver if needed
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/download.jsp?ct=DL&soid=727849&ref=EV
any further help you need let me know
