Question about HP Pavilion a705w PC Desktop
Hi, i have hp t3000. computer was in hibernation mode, i pressed the power button to wake up and now noether, the monitor, mouse or keyboard will work. any ideas
  • 111 Answers
Boot into bios and disable standby
Posted on Dec 21, 2008
I put my Dell Dimension 9200 XPS 410 into sleep mode after connecting a wireless keyboard and mouse and the only way to wake it is to hold the power button in until it shuts off and then switch the power...
I would say it is in the Hibernation Mode To get it out of this mode you need to go to your Control Panel, open "POWER OPTION'S" and deselect the Hibernation mode then reboot.
Sep 26, 2013 | Dell Dimension 9200 PC Desktop
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
I have an old Dell computer monitor that is hibernating and can't be waked up. When I try to wake it, I get an Information Box that says "Monitor is in Power Save Mode. Activate by using the...
click the mouse, move it about or press a key , if that doesn't wake the pc up, then press the power button for 1 sec, that will wake it up
Apr 14, 2011 | Dell Computers & Internet
I wiped off my computer keyboard and did npt notice anything happened when I did. When I went back to use the computer, the yellow "sleep" light was on as it usually is after sitting a while. I...
You might have put the computer into hibernate; have you tried pressing the power button? It should wake the computer up if it is asleep or hibernating. It is also possible that your monitor cable is unplugged.
Mar 07, 2011 | Sony VAIO PC Desktop
Hi! Wake-up on mouse activity is by default ON for all new connected mouses. If removing the mouse Windows (for example when moving it) Windows Vista mostly recognize that it is the same mouse, but once...
How can I wake my computer from sleep or hibernation?
On most computers, you can resume working by pressing your computer's power button. However, not all computers are the same. You might be able to wake your computer by pressing any key on the keyboard, clicking a mouse button, or opening the lid on a laptop. Check the documentation that came with your computer or go to the manufacturer's website.
Jan 05, 2011 | Computers & Internet
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
How do I get a monitor out of hibernation mode? It is not responding and did not reset when I rebooted.
Try using the power button, which usually takes the computer out of hibernation. Also, the mouse and keyboard can sometimes wake the computer from hibernation as well.
If the computer is still stuck in a hibernated state, hold the power button in for about 5 seconds so the computer fully shuts down and power it back on.
Good Luck!
Aug 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Cannot get me monitor out of sleep mode, please help?
Hi
Pls check the power management properties in device manager to check if the option to wake the computer from sleep for the keyboard and mouse are enabled.
You may also try to change the power plan or create a new power plan and check if you are able to wake the computer from sleep.
If this problem started a few days back, then you may try to do a system restore.
Feb 26, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
HP Pavilion a705w PC Desktop Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
