Question about Canon PIXMA iP1500 InkJet Photo Printer
Document printing blurred
Test page prints fine but when i print a document text is blurred and or layered i have tried brand new ink cartridges what do i do
    Novelist:
    Champion:
  • 202 Answers
You may have some custom print settings active. Go to the print properties and set the printer to default print settings. You may try downloading and installing the newest print drivers too. http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=257&modelid=10236 here is the canon site for your machine. Let me know what happens Good Luck, Tim
Posted on Mar 14, 2007
SOURCE:
Trying to print documents, white background with black typed words. Problem I have is the printed documents have solid dark blue and solid black ink and the words don't show.
Are the ink cartridges installed in the correct colour order?
Have you printed a test page through the printer's own control panel? What was the result?
Open a new document, using the default settings. Key in some test text. Try printing. What is printed?
Jan 06, 2015 | HP Office Equipment & Supplies
I have just installed a new black cartridge and when I try to print the printer says 'left cartridge missing'. It is not missing and is installed correctly. If I override the command the print
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Good Luck!!!!
Feb 19, 2013 | Lexmark X5470 All-In-One InkJet Printer
I have a Canon pixma mp990 Recently it has stopped printing with the larger black ink cartridge that is meant for printing text (PGI-220BK) All the other cartridges print fine I was using a non-canon...
It looks to me that your non Canon cartridge has blocked the print head. I see this all the time. Remember the compatables are not pigment based but just watered down ink so you can get it to flow through a syringe into the cartridge. This however is the classic outcome of trying to save a few pennies on an expensive bit of kit!
Jul 30, 2011 | Canon Office Equipment & Supplies
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
Will not print text in documents, only headings.
When you go to print on your settings select print in black only. Did you buy Brother ink? Having old cartridges refilled or buying generic can pose a problem. I remember correctly brothers have a chip on the ink cartridge? I have gone through so many printers and its really not worth going any further, seems as though you have put sometime and effort in to this 100$ printer. Take 100$ & buy a kodak easy share all in one the ink is 15$ brand new.
Jul 24, 2009 | Brother MFC 490cw Color Inkjet...
Lexmark Z600 ONLY print test pages
Seemes very daft, and sounds like a twit, but not really.
When I recieved the new cartridge I placed it in the correct cartridge retainer in the printer matching up the dark green colour of the cartridge and the top clip, and it printed nothing even after a tryed re-seating it.
So I placed it in the other thinking maybe I somehow might have placed it in the wrong slot, so I placed it in the other (Colour), and set that up as I did the other, and it printed a blurred page but then stopped printing.
After that I then placed it back in the other cartridge retainer, set it up as the previous times when it did not work, and then it worked.
Seems strange and simple, but it did not work the first time at all, and after faffing with it finally did.
This might help someone, and then again might not.
Oct 07, 2008 | Lexmark Z515M InkJet Printer
Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
May 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Printing Problems
My compaq ij300 was doing the same thing. I removed the cartridge, took a kleenex and wiped the back of the cartridge until it was completely dry and shiny looking...until no more ink would come off on the kleenex. Replaced the cartridge and aligned it using the printing software. I didn't use the test page, just typed a one-line document and hit Print. That took care of the problem.
Dec 20, 2006 | Compaq Inkjet Ij300 Printer
Test print great, document printing blurred
Have you tried a new cartridge yet? I know it doesn't make sense at first but I suspect the cartridge has a problem and your test print isn't exercising the printer like the Word doc is. If the new cartridge works than the problem is probably poor quality ink, the hole you used to refill isn't sealed correctly or the cartridge or jets were damaged in some way.
Sep 02, 2006 | HP DeskJet 3325 InkJet Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
380 people viewed this question
Clive
Clive
old marine
old marine
