Question about Dell Latitude D610 Laptop Computer - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G PC Notebook
Please tell me how to boot the Windows XP by using USB drive
We have a problem in laptop's DVD drive. so please help me to boot my laptop using USB drive
  • 2,110 Answers
You have to press F2 or Del while booting to enter BIOS..THEN in boot device priority change first boot device as usb disk..
Posted on Dec 14, 2008
  • Sibananda Jena
    Sibananda Jena Dec 14, 2008
    Why did u gave me IA rating ??
Is it possible to fix a notebook that has a message with load needed dlls for kernel. It's for a notebook. I've looked it up and it tells me to put the cd in and restore it. I have a notebook and...
Yes it is possible to fix the netbook. All you need to do is reinstall the operating system. You will have to get hold of an external DVD/CD drive or install Windows through a USB drive.
With a DVD/CD drive all you need is the XP installation CD. Connect the drive to the power outlet and then plug the USB lead to the computer. turn the netbook on and hit the F12 key or the key it tells you for "Boot Options". Select the "USB CD-ROM" device and follow the on-screen instructions to reinstall the operating system.
If you haven't got an XP installation CD then you'll have to purchase one.
You can also install XP from a USB flash drive. Click on the link I have provided below for an in-depth explanation for how to install Windows XP from a USB flash drive>>>
If you decide to install using the USB flash drive then to get the system to boot from the USB flash drive just follow the same instructions for the DVD/CD drive.
Hope this helps and please post back if there is anything else.
May 23, 2011 | Computers & Internet
The laptop has an usb connection dvd-rom. I started an installation of windows XP, by the time i got to the screen where i choose the , i found out that there is not enough space on the HD. Now i want to...
Connect the DVD drive.
Try getting in to the BIOS by tapping F2 when the computer powers on.
Go to BOOT and change the first boot device to the DVD drive. Make sure that the name of the DVD drive is listed there.
Save it using F10 and it will try to boot from the DVD drive.
Dec 24, 2010 | Acer TravelMate 340T Notebook
I have dell laptop latitude c400. Ican't reinstall the windows xp from external dvd writer. How can install the windows xp pls tell me?
This laptop will not give you an option to boot from a usb device or even from an external cd rom/dvd. You need to do a network install only for this particular model DEll c400. It is a long process and requires some skill of setting up a RIS server. You will also need a switch or hub to connect your laptop to it. Once your server is setup with dns, dhcp and ris you need to do a network boot and install the os. Get in touch with a professional to do it if your not familiar with this. I tried calling dell as i had a similar issue and they couldnt help me over the phone so they sent over a technician. Technician tried in vbain including removing my hdd and installing the os on his laptop and then putting the hard drive back into mine. It still didnt work. I then researched the net and figured out the only way to do it was via a remote installation.
Jun 13, 2010 | Dell Latitude C400 Notebook
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Install Windows xp off USB
If you are only trying to boot to windows then you'll need files NTLDR, Boot.ini, NTDETECT.COM, and NTOSKRNL.EXE on the USB drive. This will boot you to the windows screen. Trick is to get those files off of your windows CD onto your USB...then copy those over to the c:\ and that should also take care of boot problems if it was because of corrupted files.
Apr 04, 2009 | Dell XPS M1530 Laptop
Loptop wornt read cd or dvds
if your cd wont read disk then maybe it got damage. you can change the drive let it repair.
Other method installing windows is to seek USB port DVD drive and then connect it boot the system using this external DVD drive.
method 2: You have to remove you have drive and attached to other pc using drive enclosure and then copy the installation disk to the drive. then boot you system if still boot and if not not then you have to boot using DOS base system. You can search documentation installaling XP using DOS command. you can search it in
may this help,
Feb 13, 2009 | Toshiba Satellite A135-S2386 Notebook
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
Formating my laptop without cd
You can use and USB Drive, new computer boot from external drives.
Press the key to show boot menu at post screen and you can boot from an USb connected external device (CD Drive in your case)
Good luck
Dec 18, 2007 | Toshiba Satellite A105 Notebook
Dell Latitude D610 Laptop Computer  - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G  PC Notebook Logo
636 people viewed this question
Alun Cox
