Question about Tag Heuer 2000 CN1110.BA0337 Wristwatch
II would like to add links to my tag heuer
I bought a pin removal tool,but i dont see any pins,whats the trick ,sleeples in oceanside.
  • 2,334 Answers
It sounds like links has been taken out previously. Check the last link ( the one that fits directly into bracelet). There must be a hole and you should be able add links.
Posted on Dec 17, 2008
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I have tag heuer link calibre 16,i want to take ou...
your best bet is to take the watch to any jewelry store. They have a special tool to remove the pins that hold the link in place. With out this tool you risk ruining the band. J.
May 20, 2010 | Watches
I recently received a Tag Heuer Link Calbre 5 Automatic watch as a gift. However, it needs 1-2 links removed. I took it to a local jeweler and they said it can't be sized because it they weren't ablwe to...
Here is how its done. First remove one end of the clasp (this is much easier on the adjustment side - just depress the pin and remove). Now you can separate the two halves of the first link (actually this is a half-link). Simply grab each half and pull. You may have to do some twisting - do it carefully so that you don't bend the pin. You may have to do some prying - if so, you can use a thin piece of plastic so you don't scratch the link and only pry along the pin so that you don't bend it. Once removed, you can now remove the first full link. Remove it in the same way. Now replace the end half-link and re-attach the clasp. Removing a link from the other side is a little more difficult. The clasp lock is held on with a long pin (slot on one end and screw on the other. One must be held in place while you turn the other. You may need another pair of hands to help you.
If you feel uncomfortable about any of the above, take it to a jeweler - a Tag AD is not necessary but probably best although any jeweler can remove a link if they understand how they are put together. Tell them the link is composed of a right and left half that snap together and they should then see and understand what they need to do.
Apr 28, 2010 | Tag Heuer Link Automatic Chronometer...
How do i remove a link from my Tag Heuer bracelet?
I would have a jewelry professional do this due to the value of the watch. The Carrera pins, however are merely set with tension. It will take a pin pusher or similar thin rod of steel and a hammer. Tapping the pin in the watch will make it come out the other end. Pretty easy really, with the right tools.
Oct 16, 2009 | Tag Heuer Carrera WV215A.BD0788 Watch for...
How do I take off a link on the Tag Heuer WK1113
You need to pound out the adjustment link pins(s) . They are located at the ends of the band. If the watch is not too lold you can pound them out with a cut off piece of a paper clip. If it's too long it will bend when you hammer it so you will go through several of them before you finally get it out. If the band is old and the pin is stubborn you will need a very thin drift pin (tool) to push it through. Pound it through and the pin in the band will go out in front of it.
Oct 09, 2009 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
How do 5 take off a link of a Tag Heuer WK1113
tag links can be a little more tricky. take the pin out by the buckle, on the pin is out the links come apart and are held to gether by a screw. any question just email
I have lost the pin link connecting from the strap to the watch on my tag heuer, where can i get a new one? do i have to go to a shop or can i buy it online?
You should go to shop. If that pin is not 24K gold they may give you one for free. Or scavenge a cheap watch for the part you need.
Hope it helps.
Sep 13, 2009 | Tag Heuer Link Quartz WJ1110.BA0570 Wrist...
Tag Heuer watch runs fine; can't set time or date. What am I doing wrong?
Are you aware that the crown is threaded and it needs to be unscrewed and pulled out once to adjust time and twice to adjust date
Jul 25, 2009 | Tag Heuer 2000 Classic WK1311 wristwatch
Tag watch
There are several links that have a pin that can be removed. Removing two adjacent links and replacing the pin without the middle link is that way to do it. I could go on and on, but this site shows you how...
http://www.webjeweller.com/jewellery/removelinks.shtml
Ken
Aug 15, 2008 | Tag Heuer AquaracerWAF1110.BA0800 watch
Adjust links on tag heuer watches
They push out. A tool can be bought from Harbor freight
Dec 06, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Tag Heuer 2000 CN1110.BA0337 Wristwatch Logo
417 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
