My grandmother's phone recently stopped charging. It says that the battery is low and it is charging, but it is not plugged into the charger. When I plug it into the charger, it doesn't charge. I have taken the battery out and done everything I can think to do without doing a master reset! Please help me!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
