Question about RCA 32V420T 32" TV
RCA tv makes licking noise when it turns on.
The tv makes clicking noise like on and off when I try to turn it on. Then when it does finally come on it will ocasionally click the screen on and off fast. Going NUTS! PLease help.
    Novelist:
    Champion:
  • 236 Answers
It sounds like you have an arcing solder connection somewhere in the power input to your TV. This is a loose connection somewhere. You might confirm this by jarring the set while it in operation. (Not too hard) If the problem shows up then a loose connection is confirmed. Also a component may be breaking down internally. You need to have a tech check it for you. Stargazer
Posted on Mar 17, 2007
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
It started to just click for several minutes when you try to turn it on before it would finally come on....Then it started to make that same clicking noise in the middle of the night even when no one was...
Tv power supply board it is causes and the problems.That the board where the tv power a/c cord plug into it.Take the tv aparts,check the tv power supply board carefully for dying and leaking capacitors components parts.These dying and leaking capacitors components parts are alway bulges ups or puffing ups onto it tops.U have all the tools and know basic electronic?Yes,than u must changes all these dying and leakages capacitors components parts are bulges ups or puffing ups onto it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.As soon as the tv have a stable power supply board is it alway supply correctly voltages and current to the tv.These clicking noises will stops as tv turn on or the tv putting on standy power.
Aug 20, 2011 | Philips 50PFP5332D 50 in. Plasma...
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
RCA HDTV DLP 50'' TV Goes Blank!!!
The bulb went out, The clicking is the ballast trying to start the bulb
Jul 12, 2009 | Televison & Video
Phillips TV very difficult to turn on. When you
If the tv tries to get on and gets on or sometimes not and finally is working, is the symptom of the tube CRT getting to defective now. Some chance exist to adjust the circuit or maybe rejuvenate it or simply the tv is not going to work again. Some simple test in the workshop can determine the issue. Get an estimate in this issue if the problem is in the first steps is not expensive but if it is the tube then is not economical to repair.
May 01, 2009 | Philips Magnavox 27MS343S 27" TV
Vs6015r
which model do you have the VS60603 or the VS6015R? Also try pushing in input and menu at the same time on the set and hold for 8 seconds to see if the tv flashes a code.
Mar 24, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
RCA tv Making a clicking noise
This is a power supply problem it may be as simple as a blown fuse or as complex as a malfunctioning IHVT (Integrated High Voltage Transformer). Is it worth fixing, only you can answer that I would estimate the cost from $100.00 - $500.00 at least.
Sep 03, 2007 | RCA D61W136D 61 in. TV/DVD Combo
RCA 32V420T 32" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
