Its 2 years old has always ran just find until we attached it to the counter. now it wont turn on . no lights come on. the plug wires are hot. Does it have a fues or a reset button? we only moved it a couple of inches and now nothing.
Hi and welcome to FixYa,
Initially, pls check that the door locks fully and is square. Try opening and closing a few times and determine if you can hear an audible click when the door latch catches. In some other versions, there is a reset button near the rubber grommet for the AC cord. Should it require further check, then
Good luck and Thank you for using FixYa. Happy Holidays.
Looks like some parts were truncated or failed to appear.
"Should it require further check, then pls open the bottom/kick panel. Normally, there would be a tech sheet and in most instances an electrical diagram. This would help you in tracing electrical power flow and determine at which point it is missing."
