Question about USA Spec MERC99 6-Disc CD Changer
Inoperable CD changer
When I press "CD" on the radio of my 2000 Mercedes Benz C280 the message "No Magazine" appears. The changer has power but I am not able to eject the magazine. I believe the problem is a hardware problem, possibly a misguided or jammed CD. Does anyone know how to remove the magazine when the button designed for this purpose won't do the trick?
  • 3 more comments
  • John Tumulty May 03, 2007
    Thanks for the suggestions Mark. I shall try them. I have had recent developments concerning this issue:
    I took the car to a mechanic to help resolve the problem. He removed the unit from the car and the cover from the unit. Inside he turned a cogged wheel (sorry, I don't know the technical term) with a screwdriver until it stopped turning. He was then able to eject the cartridge. The unit worked well after that for only about 2 hours playing time, when the same symptoms returned. The mechanic then repeated the previous-stated procedures in order to eject the cartridge and suggested I place another cartridge into the magazine, which I did. So far the player has worked for approximately 4 playing hours with no problems. I noticed there were silver wear spots on the old magazine where the black coating had been removed. Other than that it looked perfectly normal. Not a very scientific approach to the problem, but an easy one to experiment with.
  • yorkescape Dec 13, 2008
    I have a c240 mercedes benz 2003. My cd cartridge is stuck in 6cd player. I push the button to eject and nothing happens. I only have 1 cd in it. How do I get it out?
  • Anonymous Mar 14, 2014
    how would I find out what part number will work for my cd changer(in need of the magazine)
  • Anonymous Mar 16, 2014
    Hello
    I have a clarion radio & CD multi changer in my lorry that worked OK until a few days ago. Now there's no power when you press the power button. I have tried the fuse's but they seem ok, any ideas?
  • Anonymous Mar 27, 2014
    even magazine is loaded with cds display always says no cd!
  • 199 Answers
Hi the alpine/merc/bmw cd changer all seam to suffer with the same problem, they say no disc, or no mag try firmly hitting the mag with the handle of a screw driver. the loadinga arm, tends to get stuck. you could try using some grease on the arms, and levers, white spray gease works best. but dont forget to cover the laser beforehand, you dont want grease on it :) Mark www.carradiospares.co.uk
Posted on May 03, 2007
  • Mark Waller
    Mark Waller May 03, 2007
    here to help :)
    will try and get a photo of the mech so i can show what gears cause the problem.
    Mark
After battery replaced I need instuctions to restart radio on 1999 Mercedes C280 , I have code 4 digits
If you have the code, enter it using the numbers and then press Seek or Scan when finished.
Apr 01, 2016 | OEM 1999 Mercedes C230 Radio / CD Player...
I have a MB GL 450, 2008. It has a problem with CD Changer, it loaded 6 CDs before and worked great. But display start to show that "CD is being loaded" from yesterday. No lights that indicates...
If you have a magazine-type CD changer there may be a CD jammed in transit between the magazine and the player mechanism. Disassembly may be required to find and fix the problem.
Feb 20, 2014 | Mercedes-Benz Cars & Trucks
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
Cd changer wont play
All radio accesories are on what is called a d2b ring. This ring consists of your c.d. player,telephone t.r.u. and voice activation module. On some vehicles the factory amplifier and tele aide modules are on this loop. If you have aphone see if it works. I do not think your amp is part of this ring although benz started incorporating the amp. in 2000 model years. The way this system works is that the head unit sends a wake up signal and verifies that these components work. Each components is in series and the last one in the loop sends the signal back to the head unit. It is easy to determine if you have a problem in your d2b ring if none of these components work. Although the head unit reads no changer I would make sure all of the c.d.s are installed correctly. You can also try and remove the unit and there should be areset button you can push in with a ball point pen at the base of the unit.
Jun 26, 2009 | 2000 Mercedes-Benz CLK
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
Cd magazine stuck in the cd changer in mercedeze e320
CD magazine stuck inside the changer in a 1999 E-320 Mercedes Benz.
Apr 13, 2009 | 2002 Mercedes-Benz C-Class
I have an ML320 2000, and the cd changer wont work.
Hi, The cd changer is at fault. You need to replace the cd changer. This ia very common on these vehicles.
Mar 21, 2009 | 2000 Mercedes-Benz M-Class
1999 clk 320 Cd changer says Magazine empty and want play cd's but magazine is full. anyone had this happen.
Same problem in my 2000 C280. Through dumb luck I was able to correct it in the way that I later found described in the Nov 13, 2005 post here: http://www.benzforum.com/forum/showthread.php?t=7716. No guarantee that will help you, but it did solve it for me. Good luck.
Feb 24, 2009 | 1999 Mercedes-Benz CLK
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
Mercedes ML320 CD Changer Malfunction
I can help for you. I'am live in London. Contact e-mail address: info@headunit-repair.co.uk or visit my site : www.headunit-repair.co.uk
Oct 17, 2008 | 2000 Mercedes-Benz M-Class
USA Spec MERC99 6-Disc CD Changer Logo
1,382 people viewed this question
Top USA Spec Car Audio & Video Experts
xxxxxx xxx
Are you an USA Spec Car Audio and Video Expert? Answer questions, earn points and help others
