Rca 27v414t shuts off after a few seconds...
I have this tv (rca 27v414t) it will come on for a few seconds and then it will shut off can you please help me or guide me to solve this problem, thank you. I know a litle of electronic I know how to solder can you please help me to fix it? thank you.
2 Suggested Answers
  • 3 Answers
SOURCE: rca 27v414t shut off by it self after a feww seconds.
After replacing the flyback transforer and horizontal synch transistor you will need to adjust the flyback transofrmer as follows:
Turn each setting to just above mid point clockwise, turn the tv on and you should see a white screen with retrace lines in it just before the tv turns back off. set yourself up with a plastic screw driver and prepare for adjusting the focus(top adjustment) turn the tv on and adjust the focus by looking at the pixels on the screen. repeat as needed to complete.
Next setup for the brightness (lower adjustment) turn the tv on and adjust the brightness to where the screen appears to be black(no haze or lines). After the tv turns off wait a few seconds and turnit back on, it should stay on, if not then the brightness setting it too far one way or the other and "TecniklyNuts" it correct, the system detects the setting out of range and turns the tv off. Repeat the two adjustments until the system stays on.
Posted on Feb 08, 2009
My RCA hdtv d52w23 will turn red screen when you turn it on and a few seconds later it will shut off. Whats wrong with the tv? Ive looked inside it. The red circuit board has a burned mark on it, but I...
If excessive red the set will detect too much current being pulled and shut down----Try to Google the model number with "parts" or if that fails try to contact PTS Electronics who repairs/rebuilds all kinds of circuit boards.
May 14, 2012 | RCA Televison & Video
I need a free downloadable RCA TV owner's manual....27v414t. Please help!
Hello
User manual for RCA 27V414T is not available for free download, but RCA 27v412T is available. Both of them will be equallent. If you download this manual for free get into this link
http://www.fixya.com/support/t10761282-need_free_downloadable_rca_tv
If you feel any difficuty in downloading the same, send your email address to me by Fixya comment box. I've the downloaded manual with me, and I'll send a copy of it to you by return mail. OK.
Nov 03, 2011 | Televison & Video
Rca Model number R52Wh73 Tv is not acting right
3 capacitors on your deflection board cp150 2200uf 16v cp114 cp120 220uf 35v
Dec 12, 2009 | RCA R52WH73 Projection Television
Ihave a rca 27v414t. the problem is it won't turn
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 13, 2009 | Televison & Video
Screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Feb 02, 2009 | RCA HD52W59 HDTV Projection Television
Parental Password set by mistake and don't know what it is.....
1. Make sure the TV is off.
2. Press VOL- on the TV’s front panel and then CLEAR on the remote for
approximately 5 seconds. The TV will turn back on.
3. Enter a new password the next time you access the PARENTAL CONTROL
Jun 12, 2008 | RCA TruFlat 27F520T 27" TV
Replaced convergence fuse tv worked then shut down
Sounds like the convergence power supply is defective. If you need more info let me know
Apr 29, 2008 | RCA HD52W59 HDTV Projection Television
Rca 27v414t shut off by it self after a feww seconds.
Most likely the TV is detecting an internal problem with it's circuitry and is shutting itself off to prevent further damage. You'll need to have a professional look at your set to determine exacly what's going on. Aside from leaving the power cord unplugged for five minutes, then pluggin back in and trying it again, there's nothing anyone can do from here. It may work, but it's a long shot.
Hope this helps, and please rate my advice, good OR bad.
Feb 04, 2008 | RCA 32V524T TV
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
