Question about Akai LCT3201AD 32 in. LCD Television
Power Supply rapair
How did you get your power suppy to work? What components did you replaced?
  • vccp Dec 17, 2008
    Thank you jaskylag for your help. I too found a few capacitors bubbled on top of them. I have already replaced them, but still not working. I will try working on it more.
  • vccp Dec 17, 2008
    I just wanted to confirm if LCT3201AD Power suppy board (MlT186) will work) for an Akia LCD TV model LCT32Z4ADP.
  • 3 Answers
I fixed my Akai LCT3201AD in about 30mins. using 3 small parts from Radio Shack. Once I got the back off, I found the power supply board (PSB), mine was part# MLT-169B rev1.2. I looked at the capacitors (caps.) first, because they are usually easy to diagnose. I noticed the caps. bubbled out on the top of the board (where all the cables connect to it). There is 3 of them in a row, positioned between the two large heatsinks. My guess is that the heatsinks are generating a LOT of heat over time, because of bad ventilation, and causing the caps. to fail.
I went to Radio Shack and found 3 caps. (only had 3 in stock). The original ones were 16V-1000uF, Radio Shack only carried 35V and 50V in the 1000uF caps., so I bought the 35V ones and headed home, I removed the old caps. from the board, and installed the new ones. The 35V caps, are a little bigger, so its a tighter fit on the board, be careful. It took longer to remove the back from the TV than it did to do the soldering. YouTube.com has excellent videos on how to de-solder caps. on PSB's.
Total money spent on repairs:
$1.59 ea for 3 Caps. (part# 272-1032) $4.77
$2.99 for new soldering iron tip + $2.99
$1.00 donation for St. Jude's + $1.00
Total including tax $9.30
So for less than $10, I did a repair that my local TV repair shop wanted $575 for. Online stores want anywhere from $100-$275 for a PSB. If I get another 2 yrs out of it that's well worth $10.
Posted on Dec 16, 2008
My dell xps420 does not turn on, no switch power or light, i have working internal lights
there're a couple of reasons for this.. maybe the motherboard and the new power supply is incompatible.
try removing the power cables for all the drives, just leaving the graphics card and ram seated. see if you can get into the bios. if you can, means the power supply u used is not enough to power the drives.
otherwise, try removing a component at a time to see where is the problem. try to get to the bios and hear for beeps. they should be tell-tale signs.
Dec 08, 2011 | Dell XPS 420 PC Desktop
Had a blackout and now power suppy won't turn on. Green ps light blinks and makes a clicking sound through speaker.Modelatx 300-12z cdr
Surge has possibly fried the PSU. Depending on the severity, you may find other components are damaged on the motherboard.
Best way is to test with a known good PSU
Jan 07, 2011 | Bestec (ATX100-5) (ATX1005B) Power Supply
Power button lights up but desktop will not boot. Appear to bad power supply
Change out power supply with a computer that has worked in the past and has a similar power, supply. Check power supply for 5volts,12volts we are black box specialist noone dors this any more change out power suppy and see if it works
Nov 24, 2010 | Gateway GT5404 PC Desktop
NO POWER
Check the power source?Yes,than the power supply board is dead.That the board,where the power a/c cord plug into it.Take ur tv aparts,replaced that board ur tv should work again.Try website like Ebay.com to buy a refurbish power suppy board for the replacement.
Nov 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
Power suppy was replaced but still not getting signal to monitor
It's not your power supply. It's your graphics card that's the problem.
Aug 12, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Tv screen get small at times
This could be attributed to a drying capacitor. In power supply or at the high voltage circuitry. Check first it power suppy voltage for under voltage. This can also be thermal problem for some component.
Just for some input hope it helps
Apr 20, 2009 | Sanyo Televison & Video
I Need a power suply
These units don't have a separate "power suppy" per se. There is a power transformer and a separate board that contains the standby power supply components. The main power supply components are on the main board.
Rather than looking for a "power supply", what is the problem with the unit? Is there a standby light?
Dan
Mar 13, 2009 | Sony Audio Players & Recorders
Hi vcan i ask you a question on a r40 problem
This could be a battery problem. Remove the battery and start on the power supply only. If this doesn't work, then check the power supply with an ohm meter to see if it's getting the proper output to the machine. If the supply checks good, then I'm afraid that you have a problem component on the motherboard, and will need to have it professionally diagnosed in order to track down the exact problem component.
Aug 13, 2008 | IBM ThinkPad R40 2722 Notebook
My Computer starts then turns off...
hi buddy!
be sure that the power suppy can can handle all the components thier plug. and check the power button if there is no short circuit ok. also try the other power suppy if you encounter the same problem just reply i am willing to help you ok.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 23, 2008 | Antec TruePower 550 (true550) 550-Watt...
Akai LCT3201AD 32 in. LCD Television Logo
255 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
